It is currently Tue Nov 21, 2017 11:02 pm
 Post subject: Scupper cart or not?
PostPosted: Sat Jul 21, 2012 10:59 am
I use my cart according to directions. Should I be? PA14 2011. What can be done to repair damaged scupper hole?
Hobie Pro Angler
 Post subject: Re: Scupper cart or not?
PostPosted: Sat Jul 21, 2012 12:45 pm
Can you post a picture of the damaged scupper hole?
As long as you are placing the cart full against the bottom before putting any weight on cart you should be ok. It's when you don't get the cart poles all the way in that can cause damage.
PostPosted: Sun Jul 22, 2012 4:29 am
After My Pro Angler developed a split in the hole, My dealer said that Hobie was advising against it with the heavy boats. They recommend using the strap on cradle carts. I had the boat out only about ten times when it split. I haven't seen the issue addressed by the reps here on the forums, other than an earlier general post about cart misuse when not fully inserted.
PostPosted: Sun Jul 22, 2012 7:00 pm
mine are barely just starting to show wear. I always put the cart on prior to loading in and always secure it properly.
Hobie Pro Angler
PostPosted: Sun Jul 22, 2012 7:12 pm
Not sure which year but they have started reinforcing the scuppers. If you see a black lining inside the scuppers you have the up to date version. If you have an older model, not sure if you can get the reinforcements for the scuppers. You should check with your dealer.
PostPosted: Sun Jul 22, 2012 7:59 pm
They started re-inforcing the scupper holes in the front and rear cart holes with the 2012 model.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Ambassador
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Mon Jul 23, 2012 7:12 pm
No major problems yet, but what you say above is another reason for my concern. I just dont want to be using the cart if it is going to screw up my scuppers. I will pay to get another kind of heavy duty cart if I need to, but it will suck a bit.
Hobie Pro Angler
