It is currently Tue Jan 23, 2018 9:43 am
 Post subject: Shed storage
PostPosted: Fri Jul 27, 2012 8:10 pm
I have 2 PA 12's about to arrive. I was going to store one above the other on a simple rectangular frame with 2 x 2" PVC pipes on the top level and again on the bottom. It will basically follow the design that many of you are using on your cars. But I am not limited by space between the cross members that support the PVC. With that in mind, what do you think would be an ideal space between them. Do the PVC pipes stay straight or is a bit of a bend a good thing.
Thanks in advance. : )
 Post subject: Re: Shed storage
PostPosted: Sat Jul 28, 2012 6:00 am
It's always good to be flexible :mrgreen:
PostPosted: Sun Jul 29, 2012 7:46 am
Here is what I did, just one PA14 on a lift. Used 2 block and tackles from the hardware store. Or for front and one for back. 2" schedule 40 PVC. The boards are 40" long. PVC I think is 9'. 10-11" apart.
2012 PA14 (PA14)
'85 Land Cruiser FJ60
Custom PA14 / Recreation Stuff trailer
Old Outback - SOLD
It's called "Fishing" for a reason...Otherwise, it would be called "Catching"
PostPosted: Sun Jul 29, 2012 4:16 pm
Whoops. Moved to a different album
ImageQ
2012 PA14 (PA14)
Old Outback - SOLD
PostPosted: Sun Jul 29, 2012 7:40 pm
:D
Thanks for your trouble Jfnall. You have inspired a Plan B.
So it doesn't really matter how far apart those pieces of timber are apart ....... as long as it is less than the lengths of PVC. Is that correct ?
PostPosted: Sun Jul 29, 2012 7:58 pm
My cross support spacing plan was what I thought might hold the majority of the weight of the boat, not being too close to the ends. The further apart they are, the more the PVC will flex out. And it also had to do with my rafter spacing for my hoist mounted to the ceiling.
2012 PA14 (PA14)
Old Outback - SOLD
Users browsing this forum: No registered users and 6 guests
