It is currently Sun Jan 21, 2018 2:09 am
PostPosted: Fri Aug 31, 2012 4:40 pm
I often see pictures of guys hitting the salt water with 8 - 10 poles on board a PA...they are poking out everywhere. I have trouble fishing with more than one or two poles at a time. Are you really using all or most of them when you hit the water? If so, how are you using them...are you trolling 4 or so at a time.
Just curious...
PostPosted: Fri Aug 31, 2012 5:15 pm
I carry a max of 4 rods. I have one rigged for topwater, another with a paddle tail/jerk bait, another with a fishfinder rig and the last one rigged with a cajun float.
The whole point is to have a rod rigged and ready to go when the situation presents itself.
PostPosted: Fri Aug 31, 2012 6:51 pm
I carry 4 rods if I'm fishing in a tournament, otherwise I carry 3 most of the time. I have 3 freshwater and 3 saltwater setups that I use. I don't use the rod storage holders except for transporting everything to/from the fishing spot or unless I have a rod/reel issue on the water and just store that rod in the internal rod holder tube so it's out of the way.
I do carry my Wang SOP in the top left rod holder when not deployed. Fits perfect there.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Ambassador
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Sat Sep 01, 2012 12:46 pm
I have 4 rods normally on board based on time of the year.
1- tin of some sort
2- popper of some sort
3&4 spoons for trolling.
Maybe a fifth for snagging bunker
PostPosted: Sun Sep 02, 2012 6:46 am
I fish exclusively offshore and normally carry 4 big fish rods. If I am going to a Rig/platform offshore, I will, also, take a smaller bait rod.
I normally fish with two rods, one on the bottom and one with a balloon float on top. If it is a some what slow day and the fish are all on the bottom, I may fish with three rods on the bottom (depends on the currents).
One of the reasons I carry so many rods, is if one fails or I have to cut a leader, I can get another bait back out while I am re-rigging or in the case of failure, I have a quick back up.
PostPosted: Tue Sep 04, 2012 10:08 am
If I'm a bit unfamiliar with an area I'll usually bring out two rods so I don't have to re-tie as much when switching between different plastics..
but if I know an area fairly well and have a good idea of what works best, I try to go out with only one rod.
I couldn't imagine bringing more than 3 rods out on the water with me at once. Sounds like a nightmare.
Usually have one rod rigged up with a top water and another rigged up with a suspending twitch bait. Use the top waters to find the fish and when I zero in on them I start throwing out the twitch bait. Works great for me.
PostPosted: Tue Sep 04, 2012 8:24 pm
3 rods 3 rigs= more time fishing
PostPosted: Wed Sep 05, 2012 7:01 am
I'll be interested to see if you get a good answer as to why you'd take 8 or 10 rods with you. It may help me understand the contents of my wife's purse.
PostPosted: Wed Sep 05, 2012 2:30 pm
I usually have 5 or 6, that's what fits in the horizontal tubes on the PA14. As a bass fisherman, I'm used to 8 - 10 rods out on the front deck of my bass boat. I've also been conditioned to prefer picking up another rod rigged with what I want to throw rather than changing a bait. I usually have 4 baitcasters and a spinning rod or two, depending upon season and how I plan to fish that day. The great thing about the PA IS the horizontal rod storage - the rods are out of my way, whether they get used or not, and not sticking up behind me.
2012 PA-14 Dune; 2013 PA-14 Yellow.
