It is currently Fri Nov 24, 2017 4:21 pm
PostPosted: Sat Aug 18, 2012 3:15 pm
I need to get a new mounting board for my PA. I usually get my stuff from Austin canoe and kayak but can't find anything online. Has anyone ordered one and if so what is the name for them and where did u get them. Thanks
PostPosted: Sat Aug 18, 2012 3:22 pm
I believe hook1 has a deluxe board. It was kinda pricey as I recall.
PostPosted: Sat Aug 18, 2012 3:35 pm
If your handy you can use starboard and make them yourself.
PostPosted: Sat Aug 18, 2012 3:53 pm
Mad Frog Gear has replacement boards. I think they are called PA deluxe boards.
PostPosted: Sat Aug 18, 2012 6:28 pm
Order through your dealer , Left mounting board 84502101, right mounting board 84502001
MrGreen
PostPosted: Mon Oct 15, 2012 2:21 am
Kinda late response but if your still looking, or looking for other items try
http://pathspeakspaddles.com/store/prod ... ts_id=1848{33}3405
PostPosted: Mon Oct 15, 2012 11:20 am
Remember to mount the boards you have to remove the rod tubes to get to the nuts on the bolts... Not just a simple remove and rebolt.. but might be worth it. Good Luck
