It is currently Fri Jun 23, 2017 1:41 am
 Post subject: R&R Storage on new PAs
PostPosted: Sun Sep 30, 2012 6:17 am
It seems to me that Hobie did away with some of the PAs best features in order to accommodate the new seat. Not sure I like the trade off but what can you do.
My question is what are you owners of new PAs doing to store your rods and reels above deck. If you put the rods into the forward tubes do you just let your reels lie on the deck and tangle up? Without the little stair things on each side I see no way to keep the rods separated. I thinking of maybe adding some sort of commercial rod butt storage base to each side of the hull but have not found exactly what I am looking for yet. Any ideas?
Also the side handles are now so short that if two people try to lift the boat by the side bars the thing just does a nosedive. Has anyone added additional handle length or grab bars further forward to help with this problem?
PostPosted: Sat Oct 20, 2012 4:10 am
I have only had my boat 2 months (approx.40 hrs. on the water)but I have not had any tangle problem with the storage tubes.I have used rod sleeves,but usually do not as they are somewhat troublesome to remove then store.Hope this helps.
A day on the water is better than anything else!
PA 12 Olive
PostPosted: Fri Nov 23, 2012 8:16 am
I have no issues with this problem. I usually transport my rods in the horizontal rod holders, then put them in a vertical holder just before I launch. When I do transport them, I just stagger them so the reels don't get tangled. However, I never carry more than 4 rods so there are usually just 2 rods on each side. I personally just can't see the need for more.
Richard Laughlin
Lafayette, LA
Finally Retired, Fish Beware!
2013 Hobie Pro Angler 14
2012 Hobie Pro Angler 12
2001 Hobie Hank Parker Edition Outback
PostPosted: Thu Nov 29, 2012 9:43 pm
I usually bring out between 5-8 rods depending on where I'm going and what I'm looking for, haven't had any issue yet. I usually put 4 rods in the horizontal storage then by bait catching rod and jig rod in the two vertical rod holders. Any additional rods go in the holders on the bait tank. Still no tangles and all my rods are 7'10'' or longer with the longest around 9 ft.
PostPosted: Mon Dec 31, 2012 6:59 pm
What about just using a 90 degree elbow point downward to make for a rounded end?
It's not the heat it's the humility!!!
Hobie Pro Angler
Users browsing this forum: No registered users and 7 guests
