It is currently Sun Jul 23, 2017 12:18 pm
PostPosted: Fri Mar 29, 2013 7:14 am
Hey everyone,
I know this subject has been oft-mentioned in various other threads, but I am pulling what's left of my hair out in trying to decide on a very simple items for wiring up my PA12... :roll:
All of you wizards that have installed lights, fishfinders, motors, batteries, etc etc... What have you been using for wiring pass-throughs for the hull/bulkhead/waterproof box/deck/etc??
Please, tell us rookies what works best for you, and if you have a picture and an "official" retail item name,shout 'em out for us!
Thanks! Almost time to pick up my PA and get it wet... I'm getting more anxious as the days go by and the ice remains! :cry:
PostPosted: Fri Mar 29, 2013 7:30 am
A rubber gasket from the hardware store (they make lots of sizes) and a dab of Goop. Done.
My fishfinder has terminal ends on the wires that are too large to fit through the gasket, so I simply cut one side of the gasket. No biggie.
Pro Angler-14 owner
PostPosted: Fri Mar 29, 2013 7:32 am
Do a search on "thru hull" & "mmiller" & you will get:
72025006 WIRE CAP, THRU BULKHEAD
86505621 HOBIE THRU HULL WIRING KIT
Instructions:http://static.hobiecat.com/item_attachments/86505621z2.pdf
PA 14; 2012
Cape Fear River - NC
PostPosted: Fri Mar 29, 2013 8:55 am
Drill big enough hole, pass wire or wire with molded connector through hole, seal with Permatex Ultra Gray silicone. That stuff sticks to anything. Cures up tough but still flexible.
Hobie PA14 with a mod or two
PostPosted: Fri Mar 29, 2013 8:58 am
Nice option if a bit bulky for a small wire.
PostPosted: Fri Mar 29, 2013 4:23 pm
If you goggle clamshellwiring, that's what's I like to use. You can get them in either plastic or SS. Easy to install, just fill the void with a silicone, place it over the opening/wiring and screw down. Easy to remove later if needed.
PostPosted: Fri Mar 29, 2013 5:13 pm
The PA12 comes with pass thru's for your wiring. If you need any other penetrations use the suggestions of other posters.
PostPosted: Fri Mar 29, 2013 9:04 pm
Good stuff, folks... Thanks much!
Users browsing this forum: No registered users and 6 guests
