It is currently Sat Mar 25, 2017 8:45 pm
 Post subject: HELP: PA 14 Seat
PostPosted: Thu Feb 14, 2013 6:09 am
Hi guys, newbie here. I just purchase a used 2009 PA14. It's in great condition, BUT the mesh of the seat is starting to come off:
How do I fix this problem? I tried to do a search on here with no results. I also need to clean some mold spots, what’s the best way to do this. Thanks!
 Post subject: Re: HELP: PA 14 Seat
PostPosted: Thu Feb 14, 2013 3:47 pm
The black rubber spacer is removable. Take the rubber out and place the seat material back in the grove then insert the rubber into the grove. Just like replacing a screen door screen.
It is not broke just pulling loose from the grove.
Good Luck
PostPosted: Thu Feb 14, 2013 4:26 pm
He meant to say "groove" of course.
For mold spots, a weak solution of household bleach does the trick. Or just buy a bottle of bathroom mold and mildew remover.
Pro Angler-14 owner
PostPosted: Fri Feb 15, 2013 5:54 am
Awe ok, so I don't need to take the seat apart from the back, that's good to know! Thanks.
Good ideal on mildew remover, just hose it down and hopefully she be all clean.
Thanks again.
 Post subject: Re: HELP: PA 14 Seat WTH
PostPosted: Fri Feb 15, 2013 10:16 pm
Ok I tried to remove the black strip and it won't come off? I sure I'm doing something wrong... Anyone knows a video or pictures to demonstrate how to install the mesh fabric????
PostPosted: Sun Feb 17, 2013 4:29 pm
Looks like you have to remove the seat from the boat and remove the screws from behind the seat. Just in case anyone needs to know.
PostPosted: Wed Jul 17, 2013 3:22 pm
THAT IS THE SAME THING WRONG MINE BUT BOTTOM I REMOVED THE SEAT AND SCREWS FOR THE BACK BUT IT HAPPEN AGAIN AND I AM AFRAID THAT THE TABS WILL BREAK IF I KEEP HAVING TO DO THIS.
HERO'S DON'T WEAR CAPES THEY WEAR DOG TAGS
