It is currently Tue Jan 16, 2018 2:58 pm
PostPosted: Sat Mar 23, 2013 8:37 am
Just picked up a new pa14 with a double trailerex trailer. The trailer seems about 3 feet longer than it needs to be. Can it be shortened easily?
PostPosted: Sat Mar 23, 2013 12:07 pm
yes with the right tools it can be shortened.
MrGreen
PostPosted: Sat Mar 23, 2013 1:29 pm
How? Besides undoing where the two sections are joined and cutting it shorter. It looks like the carriage can be moved forward a few feet. Is this correct?
PostPosted: Sat Mar 23, 2013 2:15 pm
The main center beam can be cut to any length you desire. It's a simple, straight extrusion. If you have a cold cut saw it will take 15 seconds. If you have to use a hacksaw, it will take maybe 3 minutes. You can cut from either end, or from the middle. If you cut from the middle, take pains to get a nice, straight cut.
And remember, you can always take off more, but it's a pain to put any back on. Measure twice, even three times, and cut once. Make sure you aren't removing length that you may need for any reason.
PostPosted: Sat Mar 23, 2013 2:24 pm
I shortened the tongue on my trailer and regret it everytime I need to back-up :x
PostPosted: Sat Mar 23, 2013 5:18 pm
I was warned just what Island speed said. I'm glad I didn't cut mine.
PostPosted: Sun Mar 24, 2013 6:45 pm
If you add a couple of bicycle safety flags or some other vertical poles elevated to say 40" or more, so you can see/ID the last crossbar on the trailer....the vision issue is solved :wink:
I did this with my Trailex trailer and I have no backing/sight issues.
The extra long trailer tongue was a pain the the arse with my Outback.
I also cut 8" off the front cross cross member as I kept running into it and my legs were not happy after an encounter.
Dr.SteelheadCatcher
Hood River, OR
