It is currently Wed Mar 29, 2017 9:56 am
 Post subject: Knobs
PostPosted: Tue Jun 04, 2013 9:00 am
Does anyone know what size screw it takes to put the knobs on the ends of the steering handles? Just got two from Austin Kayak and the included screws are too big. $10 for a plastic knob and the frigging supplied hardware isn't even correct. Pretty bogus Hobie.
Even if you fish all day without a catch, you're still better off than the worm!
 Post subject: Re: Knobs
PostPosted: Tue Jun 04, 2013 10:54 am
Hobie Tech / Moderator
The screw should be a 1/4" 20 x 1 5/8" long
Some boats had a nylon bolt installed into the handles that you first need to remove in order for the knob to be installed - please check your handle that it is compatible for a knob install first. This would be strange that a knob kit were shipped with the incorrect screw, but I suppose anything is possible.
Jacques Bernier
http://www.hobiecat.com/
PostPosted: Tue Jun 04, 2013 10:58 am
Both handles, the original and the extra one I ordered, have threaded brass inserts in the end of the handles. No nylon that I can see. Will check closer tomorrow but believe they should accomodate the knobs. It's a mystery to me but definitely will not fit.
PostPosted: Tue Jun 04, 2013 3:54 pm
I just got one from them too. Mine fit just fine.
PostPosted: Wed Jun 05, 2013 8:03 am
Guess I owe at least 1/2 an apology to Hobie. The hardware was correct but the brass inserts needed to be chased out with a tap to get the screws started in both handles. With that said, had the knob/handle ass'y been standard equipment, this problem may have reared it's ugly little head during the production process. Just saying!! :mrgreen:
PostPosted: Wed Jun 05, 2013 8:41 am
Here's a cheaper solution: Cut the head off a common 1/4"x20 bolt and epoxy all but a half-inch of it into a drilled golf ball. Perfect handle.
Pro Angler-14 owner
PostPosted: Wed Jun 05, 2013 9:24 am
RockyRaab that's a great idea. Wish I'd thought of it. Thanks.
PostPosted: Fri Jun 07, 2013 3:17 pm
I drilled an eight ball from a kiddy pooltable.
2013 PA 14 Papaya
2015 PA 17t
