It is currently Tue Jun 27, 2017 4:01 pm
PostPosted: Tue Jun 18, 2013 1:06 pm
Thinking about grabbing a bottle Rustolleum Neverwet and treating my entire PA 12 with it. Sure would help with the clean up, instead of scrubbing down the hull now I just do a light rinse and I'll be done.
Anyone else thinking about giving this a try?
PostPosted: Tue Jun 18, 2013 3:00 pm
Kinda like armorall?
Jim
PostPosted: Wed Jun 19, 2013 4:14 am
Need to put that on my rod and reels :lol:
Wouldn't it make the surface slick or slippery? If so, I'd be worried about using it on a surface I'd be standing on.
PostPosted: Wed Jun 19, 2013 4:43 am
There is a company in GA who is working on use with a similar product. Understand there are some test being done with kayaks. Not so much to keep them clean but making them go faster :!: :!:
PostPosted: Thu Jun 20, 2013 8:09 am
I recently discovered a product called "The Works". It's similar to Lime Away, even has very similar packaging, but it instantly disolved any lake scum instantly. I tried about 20 different products before I found this one. It's a miracle product for removing scum.
PostPosted: Mon Jun 24, 2013 12:06 pm
I've actually apply a good coat of RainX on the side of my PA. It does help when cleaning the waterline that I get from my primary lake. The lake is that dark "tea" colored type of environment and leaves a waterline stain. The RainX doesn't last for more than a few outings, but isn't that hard to re-apply and does greatly reduce the amount of waterline "slime" that shows before cleaning.
I suppose anything that would not impact the plastic, but would provide a slick finish would help in cleaning. I always clean my hull thoroughly after every outing and never put it away dirty. Small areas that have scuffs or scratches are the hardest to clean, but usually come clean with some elbow grease.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
2012 Pro Angler 14 (owned now by a good friend)
2013 Pro Angler 14 - Dune
2015 Pro Angler 14 - Papaya
PostPosted: Tue Jun 25, 2013 5:26 am
303 Aerospace is what I use. Not only does it make the surface slik it has a UV pertection.
Perfect for rubber and vinyl rafts, 303 penetrates the material stop brittle oxidation and UV decay
Easy application: just spray on & wipe dry
Repels dust, soiling and staining so treated surfaces stay cleaner, longer
http://www.fishingscout.com/anglers/cudadude
PostPosted: Tue Jun 25, 2013 7:46 am
We used Hobie protectant stuff on our boats and it's working great! They're in our boat slips and we just use a quick soft brush to the sides to remove the waterline marks. Still look brand new and we applied the protectant 2 months ago.
A pontoon boat forum has a similar thread going about the Never Wet. Nobody's tried it yet there either. I'm curious too.
SailHo Kentucky
PostPosted: Fri Jun 28, 2013 12:45 am
Yup, if you want your kayak to last and not degrade quicker than necessary make 303 or Hobies UV protectant a standard routine. UV degradation will shorten your yaks lifespan quicker than anything else.
303 and Hobie's UV protectant will keep it looking new and make it much easier to clean, don't bother using them on the bottom of your yak, just the top where all the sun is concentrated. It also will keep the color of your yak from fading much much longer.
PostPosted: Fri Jun 28, 2013 12:49 pm
Going to buy some Never Wet this weekend and do some testing. On the JKF website, this product has had considerable discussion and guys are trying various applications. Application to the deck of your kayak would sure make it easy to keep clean.
PostPosted: Fri Jun 28, 2013 2:03 pm
I'll be interested as well as others as to how the results are for you. Let us know how the testing goes! :D
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Sat Jun 29, 2013 3:05 pm
X2
It's not the heat it's the humility!!!
Hobie Pro Angler
PostPosted: Sat Jun 29, 2013 6:12 pm
Never Wet is not a UV protectant. Take a look at the attached link and see what this is really about.
http://www.youtube.com/watch?v=BmMGv8A4QvE
PostPosted: Sat Jun 29, 2013 8:45 pm
I'm not really interested in coating the kayak with it, but I definitely want to coat the paddle with it. I'm tired of getting dripped on...
PostPosted: Tue Jul 02, 2013 8:42 am
OK.. coated my paddle blades with this 2 part product application. First impression is mixed. While it did shed water like crazy, the coating on the paddle was a hazy matt finish which has a feeling like a very fine sandpaper. Have decided that many of the applications I had in mind aren't going to happy because of the finish of the product.
Here is a picture for your review.
Users browsing this forum: finsfan07 and 5 guests
