It is currently Sat Jan 20, 2018 6:47 am
PostPosted: Mon Jul 29, 2013 5:20 pm
kinda new to all this, but when I have to use my paddle it seems like it's to short. Do they make a extension to use with the issued paddles?
PostPosted: Mon Jul 29, 2013 5:28 pm
+1
PA12
PostPosted: Mon Jul 29, 2013 5:52 pm
Seem to be just fine to me. May be for taller guys they would feel short. BTW, I highly suggest buying those rubber gripping doohikeys ... The exact name escapes me ATM, they are like clamping holders - great to mount the stock paddle securely. Something like $8 for a pair.
I zip tied them to the right handle.
A nice plus - with the stock paddle mounted so that the blade surface is horizontal, you can use it as a cutting board of sorts, it ends up being just in the right spot.
Don't rely on stock paddle holding clamp contraption - it is too weak and a small wave can easily rip the paddle off the handle. I also use a length of paracord to secure the paddle to the yak.
Sent from my Nexus 10 using Tapatalk 2
PostPosted: Mon Jul 29, 2013 6:01 pm
Paddles on a PA are really for aux power... tight quarters turning. Not intended to be used as a standard kayak paddle or you would be right. Too short. Most are carrying a half with the t handle and using the new Hobie clip... stowing at the side of your seat and aft for easy access/ Long paddle get in the way of fishing and are not necessary 99% of the time.
71119001 PADDLE CLIP PA12
New paddle holder for the Pro Angler. Versatile part threads into existing threaded insert locations to provide secure paddle storage. You can lay the paddle into the holder, push further to snap in or use the shock cord for most sercure storage.
Or get a SUP paddel maybe?
23015575-10 HOBIE 3 PC SUP PADDLE
3-piece adjustable length SUP paddle with blade cover. Breaks down and stows in the included bag. Great for a Pro Angler while using the stand-up bar.
PostPosted: Mon Jul 29, 2013 6:17 pm
I got a multipiece paddle from West Marine and used all the sections to make my outriggers, rear floats and for paddle extensions.
Hobie PA14 with a mod or two
Some random Modification Pictures
PostPosted: Mon Jul 29, 2013 9:17 pm
Definitely too short for any real use except in an emergency. An adjustable (telescoping) SUP is the way to go: that way you can use it seated or when standing and sight fishing.
My Hobie paddle hasn't even seen the water and won't ever whilst in my hands. (If I didn't already own a SUP, I'd convert the Hobie paddle into one by chopping the paddle off the thick shaft and drilling holes for the T handle.)
Cheers,
Graeme
PostPosted: Tue Jul 30, 2013 10:12 am
Matt,
I have a brand new pa12. The paddle clip does not have the bungee strap. Should it have come with?
PostPosted: Tue Jul 30, 2013 11:07 am
Old Timer wrote:
Matt,
If it's the same as the one that Matt Miller posted pictures above, I would think the strap should come with it. I purchased a new PA14 about 2 weeks ago and all mine came with was the paddle clip that mounts to the side rails. I picked up the new style clip above and it came with the strap. It's my understanding that Hobie is shifting towards using this new paddle clip on all new PA12s and PA14s going forward.
I would give your dealer a call...
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Ambassador
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Tue Jul 30, 2013 9:24 pm
I agree with you that the paddle is too short. I use it more than I thought I would. I often fish in marshy areas or where there is heavy grass to the surface. The mirage drive will not go through that and I need to paddle through the thick stuff to get to open water again. I never use the paddle with the T-handle. I too wish they made an extension to the double paddle.
PA12 Dune
That is why they calling it fishing and not catching.
PostPosted: Wed Jul 31, 2013 10:31 am
I bought a BB 230 cm paddle. The guys at ACK recommended the longer paddle. I riveted the clip that came on the new pA12 to the female end so I can use the handle or make it a full paddle. I then attach it to my rail. The same side my stake out is on.
Steve Valerga Jr.
DV U.S.Army Airborne
1988-92
2012 Pro Angler
Take a kid fishing!
PostPosted: Wed Jul 31, 2013 11:20 am
Just put a new 2013 PA12 in garage, learned from last PA.....leaving stock paaddle in wrapper for "just in case" and buying a Accent Versa 240cm kayak /78" to 86" Adjustable SUP paddle.
http://accentpaddles.com/transformer-versa.php
~YakAttack Pro Staff ~ LIVE Watersports Pro Staff ~ RAM Pro Staff ~ Power-Pole Micro Pro Staff ~ Columbia Pro Team~
PostPosted: Thu Aug 01, 2013 5:33 am
I also carry a 230cm BB paddle. BB sold me a blank shaft that I mount on one half of paddle with the T handle. Easily converts to a push pole.
PostPosted: Fri Aug 02, 2013 6:51 pm
I bought the Accent Transformer. Probably used it equally as a push pole or stake-out pole with the anchor trolley in the bay. I liked the longer paddle for throwing low braces on returning waves in the surf.
Sandy
Panama City Kayak Fishing Assn
Users browsing this forum: Bing [Bot] and 4 guests
