It is currently Mon Nov 20, 2017 9:00 am
PostPosted: Sat Aug 03, 2013 5:18 pm
Help Matt Miller,
I removed my grey styrofoam blocks and now I need help (diagrams and directions) to reinstall them.
There a (5) different pairs of grey styrofoam blocks that I removed when I was trying to connect my GPS, FF, depth finder, and battery connections.
White styrofoam blocks on the side of my PA14:
Are these blocks held in by screws and how do I correctly remove and replace these white blocks without destroying my PA14? Diagrams and directions please!!!!!!!!!
Thanks in advance!!!!!
PostPosted: Sun Aug 04, 2013 9:50 pm
Myak....I feel for you.....I can tell you the blocks are simply "stuffed inside the hull"...friction placed and no screws are used.
A tip for those of you who need to install the same equipment......I used my 1" wide, 30 foot tape measure to "fish/feed" the cables inside the hull.
Dr.SteelheadCatcher
Hood River, OR
PostPosted: Sun Aug 04, 2013 10:01 pm
Too late now, but I wish I had numbered mine before taking them out! Doing so would have shown me where to put them and in what orientation ... :oops:
Cheers,
Graeme
PostPosted: Mon Aug 05, 2013 4:30 am
Thanks Dr. SteelheadCatcher,
I'll use your technique for future projects!
PostPosted: Mon Aug 05, 2013 4:37 am
Cheers,
Graeme
Greetings Kalgrm,
I see you feel my dilemma.
PostPosted: Mon Aug 05, 2013 6:04 am
Authorized Hobie Dealer
When we do installs we are overly careful to place the blocks out on the bench so we know which ones go where. a good idea would be to number them from front to back, put an up arrow on them and know that the number faces the center of the boat when reinstalling them.
I do not know of a "diagram" that can help you just some trial an error.
Brad Stephens
Brad@sunjammers.com
http://www.sunjammers.com
www.facebook.com/sunjammers
PostPosted: Mon Aug 05, 2013 6:18 am
sunjammers wrote:
When we do installs we are overly careful to place the blocks out on the bench so we know which ones go where. a good idea would be to number them from front to beach, put an up arrow on them and know that the number faces the center of the boat when reinstalling them.
Thanks sunjammers!
PostPosted: Wed Aug 14, 2013 4:43 pm
hmm...
is everyone's deck also lumpy?
i can understand a slow rolling up and downs as per styrofoam installs... but my styrofoams, all grey, seem to be odd shaped for the location(meaning curves seem to go backwards against the hull curvature)
is it possible to order replacement foams?
only ask because after coming back from outing, seems the foams like to shift around too...
PostPosted: Wed Aug 14, 2013 5:08 pm
kh1970......have you considered using some thin plastic sheets to "shim" the blocks?
If you hull is basically dry, I would suggest wooden shims like door and window installation shims.....
If the gap is really large.....like 1/8', you could use a 3 tab roofing shingle as a shim.....this would last a long time and water exposure is a non-issue. :idea:
Dr.SteelheadCatcher
Hood River, OR
PostPosted: Wed Aug 14, 2013 7:33 pm
It could be that the reason your styrofoam blocks are loose is because you have them spaced to far back in the PA. There is a slight taper from front to back. Shove them forward and they should fit fine.
Users browsing this forum: Sangorei and 2 guests
