It is currently Sat Jul 22, 2017 12:36 pm
 Post subject: Cutting board on 14' ?
PostPosted: Mon Aug 05, 2013 12:51 pm
Trying to come up with a design to implement. Something what would be 10x6" or so, and mount just forward of the RH rudder control knob and be at the same height as the handle bar. Ideally a sturdy, yet easily removable one, that wont require drillin holes etc.
I find myself using improvised cuttin surface a lot - cutting clam, bunker & other bait etc.
PostPosted: Mon Aug 05, 2013 1:12 pm
Would this Scotty cutting board fit the bill?
http://kayakfishinggear.com/scottyexten ... 9-1-1.aspx
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
2012 Pro Angler 14 (owned now by a good friend)
2013 Pro Angler 14 - Dune
2015 Pro Angler 14 - Papaya
PostPosted: Mon Aug 05, 2013 5:16 pm
I got a clear cutting board at Wal-Mart that is just about 10" x 6" even has a handle with a hole in the end to attach a leash to it. Cost a whopping $0.97.
PA 14 Dune
PostPosted: Mon Aug 05, 2013 5:26 pm
I am looking for ideas on how it mount it so she is right where you want it, yet could be moved out of the way easily. When simply put on the deck, it is not very convenient as you have to lean way over. Don't want to have it in your lap either, clam snot is less than pleasant.
I do have rail mounts and did look at those ball mount boards, but they seemed too flimsy to me.
Sent from my Nexus 10 using Tapatalk 2
PostPosted: Mon Aug 05, 2013 6:25 pm
How about something like this?
http://madfroggear.com/sideboard/sideboard.html
I have made something in the past with a small plastic cutting board, some t bolts and platic knobs I found at Elliots. It did the job...
PostPosted: Tue Aug 06, 2013 11:37 am
Authorized Hobie Dealer
Maybe the Stack-N-Go from Ram Mounts.
Brad Stephens
Brad@sunjammers.com
http://www.sunjammers.com
www.facebook.com/sunjammers
PostPosted: Wed Aug 07, 2013 4:05 am
OK, made something I like. Will post pics later, the paint aint dry yet. Easy one/off, very stable as it rests on the edge of the hull . Located just where I wanted it - just forward of the RH rudder control.
Might add some adhesive rubber strips to the rides so that she'd hold pieces of cut bait ...
PostPosted: Sat Aug 10, 2013 4:15 pm
And a pic:
A piece of black micarta attached to some wood with contoured cut outs, matching the dimensions of the side (width & angles). I attached some adhesive rubber strips, so that whatever bait I have in there will stay put.
PostPosted: Sat Aug 10, 2013 9:43 pm
PostPosted: Sun Aug 11, 2013 10:09 am
I see lots of fish taco's there :wink:
Dr.SteelheadCatcher
Hood River, OR
PostPosted: Sun Aug 11, 2013 10:20 am
I carry a small kitchen-type 8x12" cutting board - I can stash it away in the cooler or below the seat when I don't need it.
