It is currently Sun Jan 21, 2018 2:11 pm
 Post subject: Help! Hole on upper deck
PostPosted: Fri Aug 23, 2013 4:50 pm
I was drying my new to me PA14 (2011 model) after washing it and noticed water inside the hull. While wiping down the cockpit area I found a quarter size hole next to the built in vertical rod holer piller where the first left hand storage area drains the water to the area under the seat. I dont know how it got there or what caused it. I released the tension from my hold down strap that was running thru the two side bars and down under the yak. This seamed to allow the side of the yak to bow out a little.
Any ideas on how this might have happened and how to fix it. If I dont get it fixed all water I take over the bow that runs down the left side will drain into the hull. I use my PA in Lake Erie and Michigan and do take a few over the bow.
PostPosted: Fri Aug 23, 2013 5:07 pm
You could try to plastic weld a piece of plastic to seal the hole. I can't think of any way to get a hole that big in your PA though.
PostPosted: Fri Aug 23, 2013 6:54 pm
some pictures would help!
PostPosted: Mon Aug 26, 2013 6:40 am
Pictures would be very helpful in getting help from the folks here. If the hole can be reached from the bottom side, you can get a small package of a product called Rec'Repair. This material comes in sheets and is ideal for plastic kayak repair. You heat it with a heat source (heat gun, etc.) until it reaches 194 degrees. That makes it bendable. Peel off the adhesive backing and apply. Can use Kayak within minutes if applied correctly.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Ambassador
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Mon Aug 26, 2013 9:10 pm
Find your nearest hobie dealer and talk to them.
PostPosted: Tue Aug 27, 2013 7:45 am
I had a similar problem, in the same place. Hobie took care of me!
PostPosted: Tue Aug 27, 2013 11:15 am
Mythman mine is in the same spot just a bigger hole not a crack. I used some lexan silicon for now but not comfortable with it. Tried to post pic but not sure how to here.
PostPosted: Tue Aug 27, 2013 2:31 pm
If under warranty take it to your Hobie dealer of choice and have then get Hobie to make it right. If not under warranty, take it to a dealer who is good welding plastic ad have it repaired ( I just had three holes repaired today at my dealer).
One of the reasons is that area flexes when you sit in your PA. Make sure you got plenty of closed cell foam wedged up under that area, on both sides, to take the flex out.
PostPosted: Tue Aug 27, 2013 4:49 pm
Mythman I got the yak used so it is not under warranty. how much did it cost to have yours fixed and where can I get the proper foam for this?
Thanks for the info
PostPosted: Thu Oct 31, 2013 2:12 am
Thanks for the info
Mine was under warranty & Hobie took care of it.
PostPosted: Fri Nov 15, 2013 3:24 pm
So they replaced the entire hull for you then since it was under warranty. Seems to me that it is a design defect if the flexing causes that area to crack on a PA.
Hobie takes care of drive wells that crack even when yaks are outside the standard warranty period in many cases and i think it's only fair to consider something like this in a similar fashion.
My $ 0.02
