It is currently Sun Jun 25, 2017 3:56 pm
PostPosted: Sun Oct 27, 2013 7:59 pm
Im trying to rig my 2013 PA14 for bowfishing, what be the best way to put a trolling motor through the mirage drive hole?
PostPosted: Mon Oct 28, 2013 6:17 pm
Tell us a bit more about intended use , environment, depths. If you will be frequenting shallow water, I would recommend side mounting, so you could easily raise and lower it.
Fitting a watersnake t24 motor through the mirage drive hole is a no brainer. Adopting stock plastic mirage hole filler is also easy.
Doing the same with minnkota could be harder, the motor is larger and much heavier. Not all units would fit and even those that do, require elaborate motions.
Sent from my Nexus 10 using Tapatalk
Users browsing this forum: Bing [Bot] and 6 guests
