It is currently Mon Jan 22, 2018 4:09 am
PostPosted: Sat Nov 16, 2013 7:15 am
An easy way to hold the paddle and Stake-Out Pole in my ProAngler ..
Two bits of Elastic Nylon Cord 6-10mm used to do the job
I hope it serves to take some ideas, it's cheap and and useful.
Inside..
Stake-Out Pole...
paddle...
a hug.
PostPosted: Sat Nov 16, 2013 7:30 am
Simple but effective.
PostPosted: Sat Nov 16, 2013 6:35 pm
Nice job. What did you use beneath the side rail posts? How did you attach it to the bungee cord?
PostPosted: Sat Nov 16, 2013 9:14 pm
Hobie now has a paddle clip that came installed on my 2013 PA-14......it sells for around $10.00, P/N 71119001 and it works quite well.
The nice thing about the clip is it self threads into an existing padeye hole, adjacent to the aft, left side rod holder....no additional holes are required to install it.
Dr.SteelheadCatcher
Hood River, OR
PostPosted: Sat Nov 16, 2013 9:32 pm
I use 2 of the new taco style paddle clips. One for the paddle and one for my net. Works very well.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Ambassador
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Sun Nov 17, 2013 9:17 pm
Very cool. Good job.
PostPosted: Tue Nov 26, 2013 8:55 am
Yeah ......... I'd like some more details too ......... definitely want to use it on mine too ........ GREAT Idea !!!!!!!
PostPosted: Tue Nov 26, 2013 10:18 am
Very creative. That is the way I hook the paddle on my Wilderness Systems Tarpon 120. I hadn't thought of it for the PA. I'm on it! Thanks
PostPosted: Sat Dec 07, 2013 1:29 pm
Which one do you use?
Where do you have them mounted?
It's not the heat it's the humility!!!
Hobie Pro Angler
PostPosted: Sat Dec 07, 2013 8:29 pm
wolfewiz....see my post on the 16th...... :wink:
Dr.SteelheadCatcher
Hood River, OR
PostPosted: Sat Dec 07, 2013 10:53 pm
Here's how they look. Works very well for me.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Sun Dec 08, 2013 7:51 am
I simply don't trust the taco style paddle clips. I have lost (and found) my paddle too many times. My feeling is that if you are required to wrap a velcro strip around the clip to get it to be secure then all that tells me is that the clip isn't working in the first place!!
PostPosted: Sun Dec 08, 2013 8:08 am
Jerry,
The clips use a small diameter shock cord that hooks into notches in the clip. It holds the paddle very securely. I guess it might depend on the particular paddle you are using, but they work fine on a single Hobie paddle with a "T" handle for me.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Sun Dec 08, 2013 12:30 pm
I have a safety leash on my paddle, so losing the paddle is a non-issue for me....I like the Hobie taco saddle or cradle or nest.....I won't call it a "clip" because it's not really a clip in the true sense.
As SRAces noted, the saddle/cradle/nest has a small shock cord that secures the Hobie paddle in place.
Dr.SteelheadCatcher
Hood River, OR
PostPosted: Sun Dec 15, 2013 8:03 am
I replaced the stock paddle for a larger aluminum handled one. It is stiff enough to use for a small push in the shallow areas and holds well in the clip.
Jim
cron
