Larger rudder now available? http://www.hobie.com/forums/viewtopic.php?f=78&t=50247 |
Page 4 of 5 |
Author: | mmiller [ Wed Feb 26, 2014 9:33 am ] |
Post subject: | Re: Larger rudder now available? |
We are out of stock. The initial order was sold out. I'd guess a month or two. |
Author: | OL Sarge [ Wed Feb 26, 2014 1:07 pm ] |
mmiller wrote: We are out of stock. The initial order was sold out. I'd guess a month or two. Let me know when you get more |
Author: | Gemitaur [ Wed Feb 26, 2014 4:35 pm ] |
Post subject: | Larger rudder now available? |
Here is how it looked on disassembly. I have reassembled it the correct way Sent from my iPad using Tapatalk |
Author: | Dr.SteelheadCatcher [ Thu Feb 27, 2014 4:39 pm ] |
Gemitaur...Your first photo shows the turning disc 180 degrees out of phase......Also on page 24 of your owners manual it shows the correct location/position of the turning disc. I see why it was rubbing on the cover as the disc was in the "shallower part" of the recess. Glad you figured it out! |
Author: | Patriot [ Thu Feb 27, 2014 5:25 pm ] |
My steering drum looks like a different design thans yours Gemitaur. Glad you got it worked out now. |
Author: | mmiller [ Fri Feb 28, 2014 11:12 am ] |
To be redundant... this image and video in our FAQ shows proper position of the drum: http://www.hobiecat.com/forums/viewtopic.php?f=78&t=20521 |
Author: | Gemitaur [ Fri Feb 28, 2014 3:59 pm ] |
Thanks Matt that is what I was looking for. Sent from my iPad using Tapatalk |
Author: | NHG [ Mon Mar 31, 2014 2:03 pm ] |
mmiller wrote: We are out of stock. The initial order was sold out. I'd guess a month or two. Has a firmer date been settled on for more stock availability. Thx,NHG |
Author: | mmiller [ Thu May 01, 2014 1:40 pm ] |
Stock arrived and was rejected by our factory / engineers. I believe they were warped. No ETA on the next batch due in, but if in transit, I suspect they may also have issues. |
Author: | BRAVOGOLFTANGO [ Sun May 18, 2014 4:45 pm ] |
Patriot wrote: Alphonse wrote: Are you folks here in the U.S. who have these in hand getting them from your dealer? My dealer cannot get them yet. I just asked my Hobie dealer to order direct from Hobie Parts folks using the part number Matt Miller gave above.....84612001 RUDDER BLADE, LARGE PRO A. Thanks for sharing this, just posted on another thread about this and see it's slowly making the market. |
Author: | svendawg [ Sun Jul 27, 2014 5:40 pm ] |
Any updates on the new rudder availability. How about reviews from those that were lucky enough to get one |
Author: | kayakdannj [ Mon Jul 28, 2014 7:01 am ] |
Make a difference at faster speeds but at a stop still doesn't help, have the really pump to turn quick. I was expecting a huge difference like the sailing rudder on an outback I suppose. |
Author: | mmiller [ Tue Jul 29, 2014 10:11 am ] |
Quote: at a stop still doesn't help, have the really pump to turn quick. I was expecting a huge difference like the sailing rudder on an outback All rudders require some water flow over the rudder to be effective. You must start moving then turn the tiller SLOWLY... not hard at first. Simply jamming the rudder over stalls the rudder. The larger rudder is currently in stock. |
Author: | InlandYaker52 [ Mon Aug 18, 2014 9:24 pm ] |
Will the new PA have a bigger rudder? Sent from my iPad using Tapatalk |
Author: | keevo52 [ Tue Aug 19, 2014 6:04 am ] |
G,Day All I have recently fitted the larger rudder to my PA 12, what a difference it has made, as others have stated, it still takes a bit of forward motion to get it to turn, but hey, that change to the rudder size has now made the PA a fishing delight, yesterday I peddled upwind(10 Knts of breeze) and tied a double uni knot( leader to main line) and a loop knot to the lure without touching the steering controls once, absolutely fabulous. best thing I have done(buying the larger rudder) apart from buying the PA to start with. Tight lines Keevo |
Page 4 of 5 | All times are UTC - 8 hours [ DST ] |
