It is currently Sun Mar 26, 2017 2:05 am
 Post subject: WalkThrough of the PA14!
PostPosted: Sat Jun 21, 2014 1:18 pm
Here is a quick walk-through of the 14. You'll see my solution for the park-n-pole mounting. Also, if you have input on included rod holders vs. added holders, I'd love to hear it! I want to use the boat's holders so nothing obstructs my back cast, but maybe I'm overthinking that?
Tight lines all! See you on the water!
http://youtu.be/JLMnjBRGSe0
PostPosted: Sat Jun 21, 2014 3:22 pm
Nice video. I like the keep it simple approach you are using.
A while back Bassfriend posted his way of carrying a stakeout pole or a paddle and I am using it and like it.
Look for his posting: An easy way to hold the paddle in my ProAngler by Bassfriend.
Hobie sells an extender for the rod holders that makes them more secure. They are in the catalog.
PostPosted: Mon Jun 23, 2014 7:37 am
Dave, Nice video, hope we can get together some time. Here is my video.
http://youtu.be/L8LieYog4F0
2012 PA 14.
Love to fish, scuba, spearfish, and lobster.
Orlando to Miami.
Walter
PostPosted: Tue Jun 24, 2014 6:25 pm
Nice job!
A suggestion if i may....instead of the stainless 90's and u-bolts (good job BTW), how about this-
Remove the side handle, add a flat stainless strap under each of the handle's mounts, install the clips and reinstall handle.
Will have the same end results without the added exposed hardware.
Just a thought..... :D
~YakAttack Pro Staff ~ LIVE Watersports Pro Staff ~ RAM Pro Staff ~ Power-Pole Micro Pro Staff ~ Columbia Pro Team~
PostPosted: Wed Jun 25, 2014 6:20 am
And a very good thought it is!
That is the way I originally wanted to do it. Given the thickness of the stock, I worried about the bolts being compromised as well as water getting in around handle between the handle and stock / stock and hull, etc. Plus this is the most non-permanent way to do it to see if I'm happy with the location, etc.
If I am, I will probably modify the design to do what I wanted to do from the beginning, which is exactly what you suggested. Great minds thinks alike!
Tight lines.
Users browsing this forum: Google [Bot] and 4 guests
