It is currently Thu Apr 25, 2024 9:24 am
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Fri Mar 24, 2017 5:22 am
Greenleaf wrote:
Reviving an old thread here. Just want to say thanks to Mtmouse and others for the direction here.
I'm glad you found it useful. Looks good.
PostPosted: Fri Apr 21, 2017 1:05 pm
KansasYaker wrote:
My setup with red led lights turned on.
White leds
My battery.
I have red and green led navigation lights on the bow, a stern light pole, both red and white led deck lights under both mounting boards and lowrance elite 4-hdi.
I have the battery in a pelican case that I store in the hull on a piece of memory under the seat.
I ended up buying the same panel switch. on the back the positive terminal for each switch that you can hook up to, how did you run your ground wires from each accessory? Did you get a busbar and ran all the negatives to busbar ?
2017 Hobie PA14
