It is currently Thu Apr 25, 2024 5:37 am
PostPosted: Fri Apr 13, 2018 9:00 pm
The shaft broke off the up/down rudder assembly. I can't find a replacement. Any guidance?
Mike
PostPosted: Sat Apr 14, 2018 9:55 am
Catalog: https://static.hobiecat.com/digital_assets/International_Kayak_August_2018.pdf
Parts diagram on page 64 has the part numbers listed on the lower left.
You can use our parts lookup tool to see what each part looks like. You can enter a part number, partial number or any word or partial description text to get results:
https://www.hobie.com/parts-and-accessories/
The rudder mount has changed, so you need to be sure you select the correct one. If you have the older version (If your drum had a roll pin or cotter key holding it to the mount)... you need to upgrade the drum, pin and get a screw.
The newer version has a screw on the top:
84500402 RDR MOUNT, UNDER HULL (SCREW) US$ 27.59
The black part is: 84500201 RUDDER HOUSING, UNDER HULL
The screw that holds the rudder to the mount is two parts:
84502301 SISTER SCREW, PRO RDR ASSY
8031490 SCREW SCREW 8-32 X 1/2 FHMS-P
The parts on the top under the black plate are:
84500502 STEERING DRUM (SCREW TYPE)
8030126 SCREW (Says hex, but may be phillips)
88991235 PIN
Dealer: https://www.hobie.com/dealers/
PostPosted: Sat Apr 14, 2018 12:00 pm
Thanks Matt.
Mike
PostPosted: Mon Apr 16, 2018 6:54 pm
Matt,
I have the old style with the roll pin. I had replaced that with a cotter pin. I was able to easily remove the screw and sister screw for the rudder housing and the housing and spring are in good shape so I just need the rudder mount and the steering drum. Which screw do I need to attach those together?
Mike
PostPosted: Tue Apr 17, 2018 9:10 am
88991235 PIN
Users browsing this forum: Majestic-12 [Bot] and 2 guests
