It is currently Tue Jan 22, 2019 4:23 am
PostPosted: Tue Aug 14, 2018 12:38 pm
Just picked up a lightly used 2017 PA 14 that was kind of dirty, I thought. It has stains that look like dirt but are not. What are you guys using to clean these Yaks? I tried a little MEK and a little Acetone and neither did much good. I was happy they didn't pull the color out though.
Plan on using it in the Rockport, Port Aransas, Aransas Pass area of Texas.
PostPosted: Tue Aug 14, 2018 1:59 pm
I have good luck with magic eraser before. I had a dark stain on side of the hull that Hobie Stain remover worked like a charm.
PostPosted: Tue Aug 14, 2018 2:12 pm
Acetone??? Yikes! I would steer clear of acetone for sure. Just get it cleaned up with soap and water (sure magic eraser is fine) and fix/replace other things as needed, then worry about stains.
Thank you,
Roy Niswanger
PostPosted: Tue Aug 14, 2018 5:02 pm
Thanks to all! The Magic Eraser worked like, well, magic. The boat is in great shape with nothing to fix. I'll be adding some trinkets though.
PostPosted: Thu Sep 13, 2018 7:41 pm
I bought my PA 14 demo model and the bottom was full of scratches and I was regretting getting used. After not even a full season I've added a bunch more plus dirt and grime. I wouldn't worry too much, if you fish it hard like I do it's going to get dirty with full of scrapesbtheres no way of avoiding it.
PostPosted: Fri Sep 14, 2018 11:42 am
Consider them battle scars. [emoji57]
