It is currently Thu Jul 16, 2020 9:56 am
PostPosted: Sat Apr 20, 2019 1:39 pm
2019 PA14... I'm installing the H-Bar and the rear supports don't quite line up so some force is required to install them each time. Now, I assume that is normal. The question I have is about the bungie with the loop and hook. What is it's purpose? It's about 2 ft long. That's all. Thanks for reading.
PostPosted: Sat Apr 20, 2019 8:22 pm
If it's what I am thinking, it's used to hold your Mirage Drive fins "flat against the bottom of the hull".
The hook end is hooked onto the pedal arm and pulls/keeps it backwards as far as it will go.
Dr.SteelheadCatcher
Hood River, OR
PostPosted: Sun Apr 21, 2019 7:55 am
No. The hook is barely large enough to go over it's own bungie. It isn't big like the mirage pedal hook. It has a woven eye of bungie on one side and as it came in the H-Bar kit, I'm pretty sure it goes with that. It just wasn't mentioned in the instructions at all.
Thanks for answering the post despite me not being clear there! :D
PostPosted: Tue Apr 23, 2019 7:28 pm
Go to 6:15 minute point on this video to see it's purpose. Tie down while transporting:
https://www.youtube.com/watch?v=e7Wu4zlu3Io
