It is currently Wed Oct 28, 2020 8:08 am
 Post subject: 360 PA12 Drive Issue
PostPosted: Sat Aug 08, 2020 11:19 pm
Noticed my 360 drive was acting weird today on the water and when I got it home I could hear something inside of it rattling around. When I turned the drive upside down and shook it all of these little bars started pouring out. Any idea what these could be? The PA is on a stand now and the drive seems to functioning properly but I haven't done a water test yet.Image
 Post subject: Re: 360 PA12 Drive Issue
PostPosted: Sat Aug 22, 2020 5:29 pm
Those look like bearing rods, Do any of the fittings feel a little looser than usual? I would have it checked out before using it, as it could cause damage if used without the bearing rods in place.
PostPosted: Wed Aug 26, 2020 12:11 pm
They look like the bearing rods that are located inside the middle shaft that holds the pedal assembly together. I hope that makes sense.
PostPosted: Wed Aug 26, 2020 12:26 pm
Warranty for sure. There were some changes early on to prevent bearings from coming out. Don't recall the reason they would. Maybe global adjustment was loose?
