It is currently Mon Oct 26, 2020 3:21 pm
PostPosted: Thu Aug 20, 2020 8:23 am
67” for the Hobie cradles I’ve seen recommended here. I’m waiting on the kayak to ship, but I have a Yakima Easy Rider trailer I put together last night in anticipation.
Their isn’t 67” of spacing on the trailer (top level) to mount these cradles that far apart. I realize the cradles aren’t a Hobie product so support may be limited. I was advised by the local Hobie dealer to use the BigCatch cradles for the PA14, however.
If anyone here has a similar set up can you let me know how far apart both length and width I should mount the cradles. Or if hobie support can chime in I would appreciate any feedback.
PostPosted: Sat Aug 22, 2020 8:10 pm
How far apart can you set the cradles?
If you are using the upper level, is it possible to use the lower level instead?
The PA-14 is a heavy dog to throw on the upper level.......
Years ago I bought a Hobie Trailex aluminum trailer because it was light weight and the PA-14 was easy to slide off and on the trailer at a ramp.
Dr.SteelheadCatcher
Hood River, OR
