It is currently Fri Dec 15, 2017 1:02 pm
 Post subject: H-20 Mast Rotator
PostPosted: Tue Sep 07, 2004 11:48 am
I have seen Mast rotators on H-20 at some of the regatta's I have been to but none of the stores seem to know much about them and definatly don't have one to buy. What does it take to make one how is it attached and how or what does it do.
Also having a problem with my rudders cams not rotating back up when tripped. Any solutions. What is the easiest way to rotate them back up without pulling out the tension spring.
shane
 Post subject: Questions
PostPosted: Tue Sep 07, 2004 2:21 pm
The cam question is coverd in detail in the FAQ section...
http://www.hobiecat.com/community/viewtopic.php?t=467
All of the 20s have a standard rotation limiter. That is a rotator arm at the mast base with a line system running to each hull.
The rotator (positive rotation control)? There is a standard system we have on the 20s now. There is a comlete assembly manual (pdf) in the support area (Support link at the top of this page). Here is a direct link: http://www.hobiecat.com/support/pdfs/H20Manual.pdf
This explains both rotation systems.
PostPosted: Wed Sep 08, 2004 8:10 am
Authorized Hobie Dealer
Any Hobie dealer will be able to get you the parts you need if they do not have them in stock!
Thanks,
Brad Stephens
www.sunjammers.com
Hobie Division 15 Chairman
Authorized Hobie/Vanguard/Hunter Dealer
brad@sunjammers.com
850-235-2281
Panama City Beach, FL
