It is currently Fri Mar 24, 2017 8:19 am
 Post subject: 21 sc main sheet reeving
PostPosted: Mon May 02, 2005 8:03 am
Hey Matt Miller, or anyone else that knows...
Where can I find a reeving guide for the 21 sc? I recently got one and I really don't think it is right.
Thanks,
Dan
PostPosted: Tue May 03, 2005 8:08 am
Authorized Hobie Dealer
You can download the hobie parts catalog and there will be a diagram in there, not sure what page, that will show you how to do a 6:1 block. hope this helps.
Thanks,
Brad Stephens
PostPosted: Tue May 03, 2005 5:17 pm
thanks, I know that one is there, the 21 is a slightly different setup. Going from memory, the line anchors on the top block from a small pulley suspended below the center pulley. Attached to the bottom block is an additional pulley/rachet/cleat. It is not addressed in the assy manual.
Go Pistons!!
 Post subject: No Diagram
PostPosted: Wed May 04, 2005 2:13 pm
I don't recall a diagram of it. Basic concept would be to avoid cross overs in the lines. Allow the two blocks to be at different angles. No alignment of the blocks is necessary. I am sure the blocks were in the rigging video a few times... and the promo video. I'll look for it and try to get a screen shot.
PostPosted: Wed May 04, 2005 9:18 pm
Thanks Matt,
I've already checked out the video several times with no real luck. It's not in the assy manual or the parts manual. I know I'm close, may be correct but a diagram would be great. Also, in the video you reference stringing shock cord to keep the jib lines away from the mast. A description of this or a photo would be great.
Dan
 Post subject: Bunjee
PostPosted: Thu May 05, 2005 11:33 am
The jib sheet preventer bunjee is a simple triangle. Tied to the box up to the diamonds and back down to the box. Keeps the sheets from getting tangled in the mast base.
Users browsing this forum: MSNbot Media and 2 guests
cron
