It is currently Thu Jan 18, 2018 3:30 am
PostPosted: Mon Jun 27, 2011 10:36 am
Ok. Thanks for the advice guys. I will put it into effect this upcoming weekend because I forgot to put a mast bearing in when I stepped my mast this past weekend so I'm gonna lower my mast insert the bearing and then re-step. Any advice on doing this? I'm thinking I might just attach the step link, lift the mast out of the socket, throw the bearing in and then reseat the mast. I'm sure it's not that simple but one can hope...
PostPosted: Tue Jun 28, 2011 8:14 am
I use an electric winch all the time. Takes a min or 2 to set-up--never a problem lifting/lowering the mast. I recommend it highly.
Mike
PostPosted: Tue Jun 28, 2011 8:21 am
One of the biggest problems I have is getting the pin out of the Mast Step Link Kit (http://www.murrays.com/mm5/merchant.mvc ... re_Code=MS) after I get the mast up and the forestay attached.
I had the same problem and took a 1/4" drill and ran it through the link and mast base. Only removed a little metal but the pin goes in and out like butter now.
I'm in my early 60's with two stents in my arteries. I decided to take up sailing and recently bought an 82 H16. On a 95+ day, stepping that mast and rigging to sail can work you over pretty good.
PostPosted: Tue Jun 28, 2011 9:11 am
prunicki re: your electric winch
Can you send a picture on how you have it setup?
PostPosted: Wed Jun 29, 2011 6:35 am
Most trailers I've seen have a vertical post (mast stand) with a manual winch at the front. I attach the elec winch to the post with some bolts and plates and it sits vertically on a little shelf part of the manual winch. Just barely. I hook it to a battery--kind of like a golf cart battery--small. I added some elec line to the manual switch--enough so I can stand on the tramp and lift the mast with my right hand and operate the switch with my left. I attach the winch hook to the forestay. The elec winch lifts the mast--I just guide it. 2-3 min at most to set it up. I'll see if I can get some pix this weekend to show you.
PostPosted: Thu Jun 30, 2011 7:59 pm
dyardy
just emailed pix to you
mike
PostPosted: Thu Jun 30, 2011 9:26 pm
Here's a link to a thread that I have saved and it has been very useful. Scroll down and check out the pix.
viewtopic.php?t=7368
Mono slugs of various sizes and shapes
H 14 About 15 years ago
H 16 1982
Making Wake on A No Wake Lake!!!!!!
PostPosted: Tue Jul 12, 2011 6:17 pm
Has worked for me for the past 35 years. Give it a try.
