It is currently Tue Apr 23, 2024 4:14 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
 Post subject: Off topic
PostPosted: Fri Jul 15, 2011 5:46 pm
Did you go to Purdue and if so when?
The ox is slow but the earth is patient
PostPosted: Mon Jul 18, 2011 9:35 am
I leave my plugs in all year long... is this a bad thing? I pull them to drain and then immediately plug them again.
1982 H16 (C:\Worthy)
Yellow/White Prism type sails
PostPosted: Wed Jul 20, 2011 9:38 am
You're probably OK. The pressure change if the temp went from freezing to 100F is about 14% or 2psi. Obviously that wouldn't happen overnight and the hulls are not completely airtight (or we wouldn't need drain plugs!).
PostPosted: Wed Jul 20, 2011 9:49 am
I typically leave my drain plugs in during the season and only remove them to drain the boat and then put them back in right away. I'm more concerned about losing a plug while driving down the road than anything else if I leave them out.
Just make checking that they're in part of your setup routine. I usually check at least two times before launching.
PostPosted: Fri Jul 09, 2021 7:11 am
Hi, I lost my drain plugs! Where can I get a new set please? Are they all of the same type (can't remember it) and how many of them? I can't check myself as my hobie is 200km away from where I am at the moment. Thanks!
PostPosted: Tue Jul 13, 2021 9:42 am
Every Hobie Dealer can mail you a set.
2015 H16, with spin,
PostPosted: Mon Sep 27, 2021 11:29 am
Tip: drill a small hole in the flat part used to turn the plug, then ties a short length of line to any nearby spot so that you don't loose your plugs. I did this on all three plugs on my AIs and haven't lost one since...
