It is currently Tue Jan 16, 2018 8:45 pm
PostPosted: Tue May 22, 2012 4:04 pm
Need to replace a few missing gudgeon screws on an old style (2 separate gudgeons) H17. Searched a bunch on here and can only find info on tapping and enlarging threads. Mine are perfect - just misplaced a pair or screws and need for Friday. Thanks!
PostPosted: Tue May 22, 2012 4:10 pm
Hobie Tech / Moderator
12/24 x 1"
Jacques Bernier
http://www.hobiecat.com/
PostPosted: Tue May 22, 2012 6:55 pm
Thanks Jacques!
PostPosted: Wed May 23, 2012 6:05 am
FYI, #12-24 is not a common screw size, so its pretty unlikely you'll find them at a local hardware store. You'll probably have to go to a place like mcmaster-carr, fastenal, or your Hobie dealer to get the screws.
PostPosted: Wed May 23, 2012 7:11 am
Also, Hobie dealers carry the "locking screws" that prevent the gudgeon screws from backing out on their own.
PostPosted: Wed May 23, 2012 8:36 am
I was able to find 12/24 in 1" machine screw at Home depot. As I understand, 12 is the diameter, 24 is the threads per inch, and 1" is the length; so this should work, right? It only a temporary solution, just want to make sure it will be good for the weekend.
PostPosted: Wed May 23, 2012 9:13 am
You can use lock tite to be on the safe side.
Marc...
PostPosted: Wed May 23, 2012 11:07 am
In stainless?
Jerome Vaughan
Hobie 16
