It is currently Wed Jan 17, 2018 12:15 pm
PostPosted: Tue Jan 15, 2013 5:16 pm
I have two sets of harken main blocks that both have the adjustment screws frozen in place. I have tried an impact screwdriver and Pb boaster. Has anyone had any luck breaking these free or know if harken can rebuild them for a fee?
PostPosted: Wed Jan 16, 2013 6:50 am
I doubt Harken would offer to fix anything not under warranty. Even then, they would probably just replace it. What is a Pb boaster? Maybe you could try a heat gun.
PostPosted: Wed Jan 16, 2013 7:13 am
Another option might be to install a plastic cleat "wedge" to change the cleat angle. Harken sells these specifically for the camatic cleats.
Otherwise, penetrating fluid (WD-40, etc.) and a screwdriver with a good tip that engages well into the screw head so you don't strip out the head. Putting the block into a padded vice when working on it will make things easier as well.
I would stay away from heat for sure. These blocks are about 85% plastic, so you will almost certainly end up melting something.
PostPosted: Wed Jan 16, 2013 7:47 am
+1 on the plastic wedges if you need to change the angle.
I had a set of main blocks with the same problem of stuck adjustment screws. I wound up shearing off the screw heads trying to undo them, and had to replace the entire block...
1990 Hobie 18SX #2077
PostPosted: Wed Jan 16, 2013 7:44 pm
soak in coca cola.
