It is currently Fri Nov 17, 2017 11:48 pm
 Post subject: Where to put your weight
PostPosted: Tue Jul 09, 2013 6:42 am
Is anyone able to summarize the "standard" wisdom on where to put your weight while on various points of sail, while flying a hull, and while tacking/jibing?
Broward County, FL
1984 Hobie 16, Olympic Edition (kept in NY)
PostPosted: Tue Jul 09, 2013 10:56 am
Summarize? Transoms barely out of the water. Weight should be forward enough that you don't hear the water swirling around the transom. As the wind picks up you will have to move the weight back to maintain this attitude. The idea is to keep the maximum waterline with a smooth breakaway.
'00 H16 #104691 - '78 H16 #32692 ex-rental - Old Holsclaw trailer
My Hobie 16 pages
PostPosted: Tue Jul 09, 2013 11:20 am
When you say transom, do you mean the rear crossbar?
Broward County, FL
PostPosted: Tue Jul 09, 2013 11:35 am
Keeping the crossbar barely out of the water would be interesting.. :)
The transom is the flat part at the back of the hull, where the rudders go. If the stern is too low, the water will swirl around from the sides and create turbulence behind the transom. That is wasted energy where you are pushing more water around than you need to, so by moving weight forward a bit you lift the transoms clear of the flow. Then the water breaks away from the hull smoothly without that turbulence.
Once you know what you are trying to achieve, you can hear it. You will always have some noise from the rudders cutting through the water, but the turbulence I speak of can be created and destroyed pretty easily with weight shifts. In light to medium air it's really easy to see what I'm talking about.
My Hobie 16 pages
PostPosted: Tue Jul 09, 2013 12:00 pm
So visually, does that usually mean that the transoms are fully, partially, or not submerged at all?
Broward County, FL
PostPosted: Tue Jul 09, 2013 3:09 pm
What Anton means is that bottom edge of where the transom and hull meet should just be touching or slightly above the water, without any of the vertical transom submerged.
Chris
'88 H18SE Arís
