It is currently Wed Jan 17, 2018 4:52 am
 Post subject: Mast base rotation
PostPosted: Sat Feb 08, 2014 4:04 am
I was sailing today on our H14T and I noticed that the mast rotates to approx 90 degrees on either tack, the steps on the mast base and the base on the crossbar don't contact each other to stop this over rotation. If I recall correctly I have something like 54in of mast rake.
Am I loosing speed by having this excess rotation or any thing else?
It looks like if I made the mast a little more vertical they would limit the rotation.
Ideas?
 Post subject: Re: Mast base rotation
PostPosted: Sat Feb 08, 2014 9:01 am
Do you happen to have pictures.. Over rotating will slow you down heading upwind for sure..
It will not only change how the air "enters" the sail, but also change how the mast bends, giving a different sail shape.
www.thehobiewayoflife.com
PostPosted: Sun Feb 09, 2014 4:40 am
G'day, with the side rails level and hanging a spanner from the halyard there's 50inches to the sail cut out on the mast rake. It's close to the back of the tramp. And there's only 1 hobie mast bearing disc in there. You can see on the pictures how the mast rotation is not limited.
If I bring the mast rake back to 40inches the mast base and bottom just start touching each other to limit rotation.
Any advice?
PostPosted: Sun Feb 09, 2014 4:07 pm
That is a very old version of base and step casting. Previous to 1982. Newest set would be from 2004 and allows max rake. You can rake forward with what you have, but then will be pushing the bows down harder. I'd replace the castings.
PostPosted: Sun Feb 09, 2014 5:18 pm
Or you could cut the rotation stops off of the mast base all together and install a rotator arm (like on the Hobie 17, 18, 20, etc.). Adding the rotator arm gives you the ability to make adjustments to the mast rotation while sailing and this modification is now class legal under the racing rules. It may also be a less expensive alternative to changing out the mast base and step.
PostPosted: Sun Feb 09, 2014 6:56 pm
mmiller confirmed what I was starting to think. Could I either weld (or tap and bolt) a peice of aluminium on top of the old step at the front to get the base to contact it at my current rake?
Is 50inch of rake a good setting to use and am I losing much speed with the over rotation?
Here's a pic.
Thanks guys. :)Image
PostPosted: Mon Feb 10, 2014 3:49 pm
I've had two shops quote $150 to weld a piece of aluminum plate to the top of the step. I think that's excessive. Are the castings very thick? I might try grinding the casting down on the end of the mast and the receptacle in the step but I'll drill a small pilot hole in each to measure their thickness to see if I can remove 3mm off each.
PostPosted: Mon Feb 10, 2014 5:11 pm
Id just keep an eye on ebay for newer castings. Or just get some new ones.
1980 H16
PostPosted: Mon Feb 10, 2014 8:20 pm
ImageI think SRM has your best option with the rotation bar. Inexpensive, easy to install, doesn't involve welding aluminium and best yet You dont' have to mess with the dolphin striker.
http://www.murrays.com/mm5/merchant.mvc?Screen=PROD&Product_Code=25-304&Category_Code=C-MR&Store_Code=MS
PostPosted: Tue Feb 11, 2014 8:43 am
There is a JIB on that boat! Remove it. That'll fix part of the problem. Then put on a rotator like Hobieandy says. That is my sail you can see on Herb's right ear btw.....
PostPosted: Tue Feb 11, 2014 6:58 pm
I'm gunna try removing 3mm off the mast end and 3mm off the mast step to get the 6mm drop. The mast end is 7mm thick and step is 6mm, if it doesn't work out I was up for a step anyhow.
It was easy removing metal from the base with a belt sander, but the step is taking more time with the internal surface.
PostPosted: Thu Jun 19, 2014 4:23 am
How did this turn out in the end?
I have the same issue on my old H14 Turbo.
http://www.hobiecat.com/forums/viewtopic.php?f=17&t=51162
Hobie 14 Turbo (~1979)
Hobie 16 Carumba (1983)
PostPosted: Sat Jun 28, 2014 3:22 am
I haven't had it out since cause of winter, but there's still around 4mm left on each end, bit time consuming grinding it to the correct shape, but all good now.
