It is currently Sat Jun 24, 2017 11:38 pm
PostPosted: Mon Apr 21, 2014 1:28 pm
Hi,
I'm looking for instructions on how to mount my Gopro Camera on my Hobie. It's a Hobie 14 Turbo, but any implementations has my interest since I expect to do some adjustments anyway. Usually I'd say that "Google is your friend" when questions like that come up but I didn't find any good instructions other than this [youtube]https://www.youtube.com/watch?v=n_rGFaOwNXQ&list=PLWPCOANEVzk8yPkOGGCjooA3pJoPXhldV[/youtube]. This is fine but a lot of videos is taken from underneath the jib (on the bridles?) and from the boom. How? Instructions on how to place it safe elsewhere are also appreciated.
Regards Jakob
PostPosted: Mon Apr 21, 2014 1:59 pm
Bolt a section of the gopro arms to the bridle is how I do it.
It will squeeze between the 2 sides of the adjuster. Then use a small bolt with a nylock nut for safe keeping.
https://www.youtube.com/watch?v=94LEyuSF0Pk
I have almost busted it off once sending the crew into it on a pitchpole. So I rock a floaty back on the camera now just in case. I have not put it on boom but imagine you could just use a curved stick on mount.
1980 H16
PostPosted: Tue Apr 22, 2014 6:19 am
You can also mount a broomstick to the rearbeam/tramp and secure the broomstick with some shockcord to the ruddercastings
With the camera facing forwards
Look at my video ,its on a Wildcat but its the idea
https://www.youtube.com/watch?v=AJEmIaoH_ik
F18 Hobie Wildcat sail nr NED 16 & NED 1111
F18 Hobie Tiger sail nr 973 sold
Hobie 16 sail nr 104195 sold
470 sailnr NED 560 sold
PostPosted: Wed Apr 23, 2014 7:17 am
[youtube]http://www.youtube.com/watch?v=9fUEa7FRpCA[/youtube]
[youtube]http://www.youtube.com/watch?v=Bvqwipo0qUE[/youtube]
[youtube]http://www.youtube.com/watch?v=wHiiBqFuZ4Q[/youtube]
http://vimeo.com/63503927
http://vimeo.com/28782914
PostPosted: Thu Apr 24, 2014 11:04 am
Awesome. This certainly gives inspiration.
Regards
PostPosted: Fri Apr 25, 2014 1:59 pm
Regards
Thanks! :D
PostPosted: Wed May 07, 2014 1:19 pm
Can anybody post a upclose picture of their goPro mounts. I like how it is positioned in the video of the first post.
Many thanks!
PostPosted: Wed May 07, 2014 11:08 pm
You just need to think outside the square with mounting your GoPro.
Top of mast I used a hold stay adjuster which I push to a forward position. This gives the best view IMO as the rear is covered up by your main sail.
And at the front I mount attached to the hole stay adjuster (forestay bridle). I just drilled a hole in the actual display GP piece which comes in the box. I have then added afew GP mounts which help to move your GP around to specific positions/angles. This also lowers your mount so that the vision isn't blocked by your jib.
HTH
2007 Hobie 16 - 'Slingshot'
1996 Hobie 18 - 'Onrails'
Hobie Bravo - 'Hobie Bites'
PostPosted: Thu May 08, 2014 10:07 am
note to gopro users. Use a floaty back! I sent my crew (pitchpole) into the bridle mounted cam and busted the mount once. :mrgreen:
1980 H16
PostPosted: Thu May 08, 2014 10:19 am
Better yet, tie it so something permanent with a "leash" line. I whipped up a dyneema line that kept the gopro attached to the boat in case the mount broke. I think I ran it through the hinge of the gopro case so that it would still hold even if the mount broke.
Zach
PostPosted: Thu May 08, 2014 10:20 am
Like this:
Zach
PostPosted: Thu May 08, 2014 11:08 am
Awesome! That's really helpful. Thank you all!
P.S. Cool Pic with the guy flying out...
PostPosted: Sun May 11, 2014 11:49 pm
Matt that's a pretty cool mast head mount. Do you just use the app and wifi to start stop the camera or do you just turn it on and let it roll?
I saw somewhere a person made a swivel mount for the bridle, so gravity kept the gopro level with the horizon while they flew a hull. I thought that was pretty radical.
1978 H16 "Frank" we love him cuz he's different
PostPosted: Thu May 15, 2014 3:19 pm
Try the tiller arm (not crossbar) with a pole mount. I tried this last time I went out, but left the camera on "narrow" FOV, so the result was garbage. On "wide" FOV it should be an interesting view to mix in with other angles. Putting it on the tiller extension pointed at you could be interesting too, especially while on the trapeze.
Bradley M. Davis - Hobie High Life YouTube Videos
'76 H16 Flamer #20060 - SOLD
'87 H16 Prism #90350 - SOLD
'84 H16 Blue Hawaii #79922
PostPosted: Thu May 15, 2014 10:57 pm
sfvanman I use the GP remote attached to my PDF to continually turn it on/off. You can also get the wrist bands for the remote which are handy.
Even turning it on/off I find the battery life with wifi doesn't last long so I bought a pack of Wasabi batteries. Wasabi batteries are fantastic and half the price of the genuine gp ones. The three batteries last me a full days sail so nothing great is missed!
