It is currently Tue Apr 23, 2024 11:24 am
PostPosted: Tue Aug 21, 2018 11:52 am
My H16 currently has the Trenteck Jib Traveler car system (Jib Traveler cars that are controlled with a sheet that is tied to the traveler car, then runs through a cheek block then a cam cleat on the corner casting, then to the other corner casting, through the cleat, then block then to the traveler car.)
I recently acquired two of the Jib sheet car W/ Blocks that can be locked into the jib traveler track via a spring loaded handle on the block. I am thinking I am going to change to the locking type.
What are the advantages/disadvantages of each? What should I know about them?
I am a fairly experienced H16 sailor, but don’t race or care about shaving Nano-seconds off my time. I am thinking the system with the locking blocks would be one less sheet on the tramp, and a bit easier for my crew to handle. I wouldn’t adjust my jib traveler blocks much anyway.
Thanks for your advice!
Danny
PostPosted: Tue Aug 21, 2018 3:25 pm
Yes, the block on the car will run easier too. Less friction on the sheet than the tren tec cars. I would swap and dumb the traveler system.
Users browsing this forum: jclarkdawe and 2 guests
