It is currently Wed Mar 29, 2017 10:43 am
 Post subject: Replacement Sideboards
PostPosted: Sun Jun 20, 2010 8:08 am
http://madfroggear.com/specialtyboards/ ... oards.html
PostPosted: Mon Jun 21, 2010 8:33 am
How do you remove the two front screws on the side boards? The back two come out withoiut a problem the front two just spin. Do you need to remove the rod holder tubes to get to a nut in the hull?
PostPosted: Mon Jun 21, 2010 9:03 am
Hobie Tech / Moderator
Yes - you need to access the inside to remove a nut on the back-side
PostPosted: Mon Jun 21, 2010 9:34 am
Thanks. I was going to try that.
