It is currently Thu Jan 18, 2018 6:32 pm
 Post subject: Additional rear handle
PostPosted: Sun Jul 11, 2010 5:59 pm
I lift my PA by the rear handle to get in onto the tailgate of my truck for transporting. It's heavy and awkward to use just the rear handle so I added and additional handle to assist me. Sure would be nice if Hobie added and additional handle or and indented rear grip.
http://www.flickr.com/photos/35983350@N03/4784410227/
PostPosted: Mon Jul 12, 2010 3:50 pm
Great idea! Hobie does offer handles as an accessory, PN 71190001. I use several on my boats -- one can't have too many grips! 8)
PostPosted: Tue Jul 13, 2010 6:28 pm
They look great. Thanks for the part number!!
PostPosted: Wed Jul 14, 2010 6:39 am
In the picture number two, did you place a metal plate for backing inside the yak? Looks like you might have voided the warrenty with that set up... Just a thought...
PostPosted: Wed Jul 14, 2010 10:43 pm
Stainless flat washers in all cases.
Why do you think so? 8)
PostPosted: Fri Jul 16, 2010 6:30 am
Location of handle is low on the curve. Stress and pull when lifting might cause a crack in the hull... BUT this is just a guess on my part. Good luck.
PostPosted: Fri Jul 16, 2010 8:15 am
It's true, Hobie's warranty does not cover "damage by alterations or modifications", but it does cover "defects in material and workmanship". Fortunately one does not necessarily affect the other.
It's a good point though -- a lot of users wonder if making a modification (installing a ram mount for instance) voids the warranty. It doesn't, as long as the ram mount doesn't cause a failure. Many Hobie accessories require modification to the hull, such as Sidekicks. Often, modifications are installed by the Hobie dealers -- doesn't matter.
As for the grips, I've been using them for a couple of years now and find them to be very useful and problem free. 8)
Users browsing this forum: No registered users and 7 guests
