It is currently Wed Mar 29, 2017 4:10 am
 Post subject: My beach cat ramps
PostPosted: Tue Jul 06, 2010 5:00 pm
2 by 8's x8' long with 3" PVC hole saw (3 1/2" dia). Work like butta. Just pounded the PVC in, no pins. Use dry pressure treated lumber if you don't want to work hard at the hole sawing.
http://picasaweb.google.com/lh/photo/0ty2X3JFiUCkGldNSTrGmw?feat=directlink
 Post subject: Re: My beach cat ramps
PostPosted: Wed Jul 07, 2010 10:11 am
that looks pretty slick. I may steal that design.
Division 10, Fleet 185
Hobie 17 and Hobie 14
PostPosted: Wed Jul 07, 2010 11:28 am
Here they are in action.
http://picasaweb.google.com/divimon2000/Hobie02?feat=directlink
PostPosted: Thu Jul 15, 2010 8:55 am
For what it's worth, I saw something similar once but the guy added flexible radiator hose around the PVC. It cushioned the hulls a little and was also just large enough to rotate around the PVC turning them into rollers. It was pretty slick.
'81 H16
PostPosted: Fri Jul 16, 2010 4:59 am
My husband made a similar design three years ago. They work quite well. It is drainage tubing around the PVC pipes. The wide width permits you to "sail up it" when coming in. Easier to hit than a narrow one would be.
PostPosted: Fri Jul 16, 2010 8:14 am
Saw those- amazing. I opted to cheap out, they ended up being $50 a set as they are. Mine work well, the are showing a tad of wear but I figure I can twist the PVC around if need be.
PostPosted: Sun Jul 18, 2010 5:04 am
rjack22
Very cool idea.
MP
PostPosted: Mon Jun 10, 2013 4:37 am
Has anyone else made similar ramps? Can you describe them or post pictures please!
PostPosted: Tue Jun 11, 2013 10:38 am
I made some using pressure treated lumber and made them 18 inches wide. I drilled holes in the lumber, put the smaller diameter pvc through the hole and capped one of the ends. I then cut a lttle bigger pvc, put it over the smaller and then capped the other sides pvc. The bigger pvc then rolls allowing the Hobie to be sailed up onto land. I made 2 of those 8 feet long for less then $50 and use pvc lattice to move the baot around once on land
Brooks
PostPosted: Wed Jun 12, 2013 6:37 am
Do you know what size PVC you used for inner and outer? Do you think the rollers were necessary? It seems like the boat would just slide across the PCV without the rollers, but not as well. Do the roller "bearings" get full of sand? Did you glue the caps?
How did the PVC lattice work? that is a great idea?
