It is currently Sun Jun 25, 2017 12:28 pm
Post new topic Reply to topic  [ 19 posts ]  Go to page Previous  1, 2
PostPosted: Tue Aug 03, 2010 2:28 pm
dosjers wrote:
Cowsgomoo said something about side scanning. I'm not sure what kind of fish finder he has that uses side scanning.
It's a Humminbird 798. Here's a pic of the beam pattern.
As you can see it uses beams out to each side (Unless you leave your wheels in...) as well as a traditional look down beam.
PostPosted: Wed Aug 04, 2010 4:58 am
I stand corrected. If you are using a side viewing depth sounder you can't shoot through the hull. But then, how many people are going to buy a $1000 depth sounder for their kayak?
I still think that for the vast majority of AI & TI owners gluing one inside the hull is the way to go. When I launch the only thing I have to do to make mine work is turn it on.
Jerry
Jerry D.
St. Johns, Florida
2010 TI
2008 AI
PostPosted: Mon Aug 09, 2010 7:34 pm
For the life of me, I can't figure out why anyone would want an external transducer mounted so low in the water. I have just installed a Lowrance HDS5 with external transducer, and having the transducer sit an inch under waterline works well enough, not popping up, no negative effects at higher speeds. It works a treat.
Photos and commentary on my install job here: http://yakass.net/articles/87-equipment/558-mounting-the-monster.html
Blue Water Kayak Fishing guy: SL Hobie
http://slhobie.com.au
PostPosted: Thu Aug 19, 2010 4:04 pm
I mounted everything outside as I wanted it to be, maybe the bracket that holds the transducer will be shortened to just below the waterline. Now all ok! good sign!
http://picasaweb.google.com/MR.SPIRRITT ... 5500271474
