It is currently Sun Jul 12, 2020 12:23 am
PostPosted: Mon Aug 09, 2010 7:19 pm
Hi all, Im waiting on my TI. Trying very hard to keep busy & distracted, by thinking about it & every little thing that it involves
Anyway do any of you that do a lot of open water/bay sailing have baffles or floatation aids in the hulls of your AIs or TIs?
Is there any need?
I know the hulls are strong but never say never, would the outriggers be enough to keep a cracked hull afloat long enough to get back to shore?
If you do, how did you do it? What did you use?
Cheers
PostPosted: Mon Aug 09, 2010 9:15 pm
Some guys throw a few pool noodles in their kayak. The nice thing about the TI though, is you have 3 independent chambers, any one of which should prevent the boat from sinking. 8)
PostPosted: Mon Aug 09, 2010 9:32 pm
Hi mate, is that 3 chambers in the main hull or do you mean the hull+outriggers?
If its 3 chambers in the hull then its good to go
PostPosted: Tue Aug 10, 2010 12:56 am
Ping-pong balls. :idea: Fill the hull with ping-pong balls!
Or you could recycle plastic bottles, like these guys:
http://www.theplastiki.com/
The Wind Is Your Friend...
PostPosted: Tue Aug 10, 2010 4:29 am
I'll be looking at some flotation for when I get offshore. With the main hull swamped, for example if a drivewell cracks etc, the TI may well still float, but you sure won't be going anywhere under your own steam.
The main hull is a single compartment, so I'll especially be looking for flotation bags fore and aft, and perhaps something around the drivewells etc. It may be a challenge to not interfere with steering lines though. But I want a fighting chance of getting back to land myself.
PostPosted: Tue Aug 10, 2010 4:45 am
There have been a few instances reported on the forum of people noticing their AI was sluggish, then discovering after landing that the hull was full of water. There never seems to have been a question about them making it home.
PostPosted: Tue Aug 10, 2010 5:53 am
Noodles work great...
CaptRon
"Anything's gonna happen,
it's gonna happen out there"
PostPosted: Tue Aug 10, 2010 6:42 am
If I'm not carrying any cargo in the front and rear hatches, I use two sea kayak air bags.
PostPosted: Tue Aug 10, 2010 5:02 pm
Dregsfan, what size do you use and recommend for the AI?
Do do you inflate those before leaving shore? I assume you would.
Like the proverbial PFD which is never worn, airbags would only truly be effective if checked for leaks and inflated in-place prior to launch. They have a great chance of working then.
If you haven't done this, can you imagine bobbing in swells, moving gear around, positioning the floats and blowing them up when the bow 1/2 full of water? How long would you need to straddle the hull, blowing with the front or rear hatches wide open?
You might also need to blow hard enough and fast enough to displace 100+ lbs of H2O. That's a great physical stress.
I would love to see a large self-inflating model that you could use at sea, but floats are expensive enough as is.
As you can tell, I'm more a fan of passive floatation devices. As Cpt-Max says, pool noodles are effective (and a bit more practical than pong-pong balls).
A couple noodle layers can be bent neatly into the bow/stern. Pieces can be cut/taped together to form a custom hull liner that helps keep your other gear stowed dry and tight (a nice way to store your anchor). They even come in matching Hobie colors. Yes, pink too. :lol:
If you have spare PDF's at home, throw them in the hull on every trip. They stuff nicely into any cranny and could save the day - or someone else's life. Guaranteed to work and costs you nothing.
As Plastiki proves, sealed empty plastic containers like gallon- sized milk/water jugs will add float to your boat. Those w/ handles can double as floats for your snorkel gear, anchor lines and such. Cut them a bit and they make great bailing devices. (As you can tell, I'm thrifty too).
I guess it's time for someone to mention hand pumps and bilge pumps now? Image
PostPosted: Tue Aug 10, 2010 5:08 pm
Not sure what the size is. I think they're around 36-40" long. Any sea kayak float bag will work.
PostPosted: Tue Aug 10, 2010 5:33 pm
This is something Matt should weigh in on. Hobie should have tested this. But if there are any unfortunate "Beta testers" out there, please speak up.
In the event of a full hull or a hatch breach I doubt the AI would be sailable on anything but a calm lake. If you could sail the submarine, it would be interesting. The rudder would be underwater half the time and up in the air at others. The bow would plow on any sizable wave and possibly set you up for pitchpole downwind. The mirage drives will still work to some degree but will be under heavy stress.
Maybe our Adventurous Aussie friends are willing to try this little test too? :?:
I can tell you that if you have a large passenger (or heavy gear) onboard and the AI takes on more than half a hull of water at sea, you will not be going anywhere. At least, not where you intend to go. I have seen this for myself.
You will stay afloat though. Thanks to those Amas.
PostPosted: Tue Aug 10, 2010 6:59 pm
OK, I'm speaking up. :)
On a trip last year with 3 AI's, over a 12 mile run, when we put the scupper cart under my red AI (yep them troubling red ones) and started to pull it up the boat ramp, it wouldn't budge. Boy I must have been tired. Then, my friend who had been in it grabbed on to help me, and still no go. I opened up the front hatch and it was 80% full of water! :shock: The mirage drive well had cracked in the front and the boat had filled with water. We had not noticed much difference in his speed or maneuvering ability before this.
So, in my experience, an AI can float and sail just fine with a hull mostly filed with water. Who would have thunk?
http://KayakingBob.com - - - - - - - - - - Hobie Island Sailing since 2006 - - - - - - - - - - SpraySkirts
PostPosted: Wed Aug 11, 2010 12:07 am
Same here.
We had a boat swamping offshore with 2 aboard. I took the passenger on my tramps and the pilot was able to limp the AI to the harbor. They had a hard time with the rudder in the swells and was lucky there was not pin failure.
It was a happy landing, but the AI dragged up on the sand like a beached whale!
PostPosted: Wed Aug 11, 2010 2:31 am
The pingpong balls might not be such a bad idea mate, when the hull cracks they'd just have to follow the white trail to the yak & hopefully you hanging onto it
I like the idea of the airbags though the noodle idea is great for the budget. Ill definately be getting a hand bilge pump
Cheers for the input, any other great ideas people?
Also great to know the Islands can function with pretty serious hull failure, how was the weather with both these incidents?
PostPosted: Wed Aug 11, 2010 10:41 am
Well, here's one of my favorite pictures from that day. The red AI closest to me is the one that leaked.
