It is currently Sun Jan 21, 2018 3:08 pm
 Post subject: H14 rudder mount
PostPosted: Thu Sep 09, 2010 9:03 am
One of the screws in the top rudder mount (or gudgeon) of my H14 has pulled out and there is no remaining thread.
Does anyone know if the rudder mounts screw into captive nuts, or do they thread straight into the fiberglass?
Sullivar
 Post subject: Re: H14 rudder mount
PostPosted: Thu Sep 09, 2010 10:34 am
There is an aluminum backing plate that's glassed into the inside of the transom. If your existing gudgeon screw is a size #12 (stock?), it can easily be tapped (no drilling) up to 1/4 inch dimeter, and 1/4 inch SS screws are available at most local hardware stores.
Jerome Vaughan
Hobie 16
PostPosted: Thu Sep 09, 2010 10:39 am
Thanks Jerome - much appreciated
PostPosted: Mon Sep 13, 2010 3:49 pm
Yes it is important that you not try drilling. I learned this the hard way. Just tap a new 1/4" thread directly into the existing material as mentioned above.
Justin (Lafayette, CO)
'81 Hobie 14T "Two Hull and Back"
'78 Hobie 16 "Two Hull and Back Again"
