It is currently Tue Apr 16, 2024 12:53 pm
 Post subject: TRAP HARNESS
PostPosted: Thu Apr 13, 2006 8:14 am
Could i use my DaKine Windsurfing Harness to trap on my Getaway?
 Post subject: Harness
PostPosted: Thu Apr 13, 2006 9:05 am
Usually the windsurfing harnesses are built lower on your hips. You could use it, but it may feel like you are going to tip out of it. The spreaders (hooks) are also different. The typical trapeze hook is a single rod of stainless bent into a simple hook. The windsurfing stuff usually has a doubled over (wider) hook. You would need some trap handles like a J&H wire loop to use it.
