It is currently Mon Jan 22, 2018 1:22 pm
PostPosted: Sun Oct 12, 2003 10:49 am
Is $1500 for a 1984 Hobie 16 a good price? It has been used little since 1989 and appears to be in good shape from pictures. It does not have a comptip, but has Harken blocks and EPO rudders.
PostPosted: Sun Oct 12, 2003 8:07 pm
Authorized Hobie Dealer
Make sure that there aren't any soft spots in the deck. The price sounds about right as long as everything is there. Not having a comptip isn't a huge deal unless you are going to race, then go to your Hobie Dealer and order one, they will sell it to you at cost and should cost about $50 bucks to install. Good luck, You can never go wrong w/a used H16's hold there value extremely well.
Brad Stephens
www.sunjammers.com
info@sunjammers.com
Panama City Beach, FL
850-235-2281
 Post subject: Adding a comp-tip
PostPosted: Wed Oct 15, 2003 10:54 pm
I have an '84 16 as well - no comp-tip - you can add them without replacing the entire mast? It's a one peice mast though...?
G
 Post subject: Re: Adding a comp-tip
PostPosted: Thu Oct 16, 2003 10:51 am
G
Gotta do the old cut and fit routine
cron
