It is currently Sun Mar 26, 2017 12:10 am
PostPosted: Sat Jul 16, 2011 2:20 pm
Hi, my hc14 has a jib and trapeze but does not have the Turbo decal on the hulls.
As I have some doubt on the current shrouds (their diameter seem low, about the same as the trap wires) intend to change them, should I take hc14 shrouds or hc14turbo ones?
My shrouds attach to the sidebar, on the Turbo manual available in the FAQ they seem to attach to the hulls like on a 16.
PostPosted: Sat Jul 16, 2011 6:52 pm
The shrouds on the 14 Turbo are identical to the 14's, and they attach in the same location - on the sidebar.
Only 14s made in the last few years (and only in Europe) have shroud attachments on the hulls like the 16.
The stock 14's (and turbo) shrouds are 3/32" diameter - the same as the trapeze wires. Some aftermarket (Salty Dog) shrouds are 1/8".
PostPosted: Sun Jul 17, 2011 7:21 am
I just replaced mine as one of the 3/32" shroud failed and I was dismasted last weekend. Fortunately there was an onshore wind. I was able to pull the mast aboard, hold a section of the sail up by the batten and create a kind of wind tunnel and to steer the boat ashore. I must say I don't know how old these wires were because I just got the 1982 Turbo this year.
I ordered a new set from a Hobie dealer (Backyard Boats) and the ones I received were 1/8". Like you, I was a little nervous sailing with the smaller diameter wire.
PostPosted: Sun Jul 17, 2011 2:39 pm
My question was triggered by my reading of the Hobie parts catalog which has two references:
14070530 for Hobie 14 Shrouds
14070535 for Hobie 14 Turbo Shrouds
from the replies it seems the shrouds are the same, so why have two references?
PostPosted: Mon Jul 18, 2011 2:24 pm
I see only one part number for H14 shroud wires, 10792100. Where do you see another?
PostPosted: Mon Jul 18, 2011 2:46 pm
These are not Hobie USA part numbers, so may be different in Europe.
Hobie USA has just one wire... it is # 10792100
Years ago, we had two. The H14 was a smaller diameter wire.
PostPosted: Mon Jul 18, 2011 7:25 pm
That explains it - one short for the sidebar attachment point; one longer for the hull attachment point.
PostPosted: Mon Jul 18, 2011 10:24 pm
The shrouds which attach to the hull have yet another reference (14070536), for hobies made in EU after 2007.
I called my dealer, he did not know either why there were two different references.
