mmiller wrote:
Wing parts kit would be all the installation hardware. Not the end castings.
The strut is no longer available. That is simply a short rod of aluminum stock. You can get that from home depot.
Thanks Matt. Is the kit for both sides, or do I need 1 kit per wing?
Does anyone know what the dimensions (length, diameter, wall thickness) or the strut are?
NAHCA555, I'll keep that in mind. I think the P.O. found that one out the hard way as well, as one of my legs has been welded back together! (I know, welding ruins the heat treatment of the Aluminum, its on my to-fix list, just not this time)
