It is currently Mon Nov 20, 2017 10:10 pm
 Post subject: Leaki wing pockets
PostPosted: Mon Sep 12, 2011 9:08 pm
I just got my new (old) H17. Sure enough, got 2 wing pockets that leak. One in front I can fix by fiber-glassing from inside. The one in the back have no access from inside without ripping the the top of the hall. Here is what I was thinking doing:
1. Gel coat the crack. This is very limited in thickness of the repair. Else, the wing tube will not fit.
2. Lots of grease in the tube
3. Electrical tape at the top of the pocket-tube junction to seal it
4. Duck-tape the top of the tube every time the wing get replaced
Does anyone have a good luck in fixing this issue?
H17
 Post subject: Re: Leaki wing pockets
PostPosted: Tue Sep 13, 2011 9:41 am
Check the May/June 2006 Hotline for how to repair the wing tubes. The article provides comprehensive instructions for fixing a broken wing tube from the outside of the hull.
Simply gelcoating the crack will not solve the problem. Gelcoat has very little strength, so it will almost certainly just crack if you don't reinforce with glass fibers.
Do NOT put grease in the tube. This will attract dirt and sand and make a huge mess, especially evertime you pull out the greasy wing.
I've done the duct tape thing around the wing tube/socket. It definitely helps to keep water out, but it's messy and you have to do it everytime you sail. If you fix the wing socket properly, there's no need to do this.
PostPosted: Tue Sep 13, 2011 10:39 am
Looks like it's time to put in some 4" access ports just infront of the stern tubes. Cut the holes, do the repairs, then install the ports. :wink:
PostPosted: Tue Sep 13, 2011 3:13 pm
While the May/June 2006 Hotline definitely has great info I would not go so far as to call it comprehensive especially if you have never done any of this before. I am facing the exact same repair as you on all 4 pockets and while the information in that article in invaluable I do not feel like it tells me everything I need to know.
I would really like to hear some in-depth info from people here who have done it before. I am all about do it yourself but I have never done fiberglass work or gelcoat work before. I have research online and read pretty much every this old hobie article and others so I fell I have learned a lot but this repair is nothing like any of those.
For starters when adding glass inside the hull to the outside of the pocket how do I apply it?
Do I wrap it around like an ace bandage or lay it inline along the length of the tube?
Do I need to sand the the outside of the tube before laying in new fiberglass? If so How much?
The fiberglass tape will be impregnated with resin before I try to apply it to the outer part of the tube but do I need try to squeegee more thru it to get it o adhere to the old glass? This seems like it would be pretty tricky on the round tube of the pocket. Should I just try to get it in place and then with gloves on just massage all the resin into it?
When doing the inside I get that you need sand off the gelcoat with a drum sander and I assume you apply strips of impregnated tape lengthwise down the tube but again how to you promote good adhesion to the old glass? It is not like you can squeegee it in.
How to address the bottom of the pocket. All my tubes seem to drain pretty much all the way so I have to assume that I have leaks all the way down or at least at the bottom. How do get glass in there or do you just pool some epoxy down there?
How do you re-gelcoat the inside of the tube?
Some of you who have done it please speak up and share your knowledge. The Hobie article is good but i don't feel it is enough for this big of a job.
PostPosted: Tue Sep 13, 2011 6:52 pm
Thanks everyone for replays and good info. Quarath brought up a good point. Try youtube and search for fiberglass repair -- there are tons of good info there.
I was hoping I do not have to make a hole in the boat. This is just like asking for a major surgery fro a family member.. :)
I've ordered my 4 inch access panel today.
Cheers good winds
H17
PostPosted: Tue Sep 13, 2011 8:03 pm
I have watched many of them but it is hard find anything specific to this.
As for the port if you don't have one that should not be a hard thing. Put where you can reach where you are working buy the port first and measure it before cutting anything
The hobie hotlines especially ones with the this old hobie section are a wealth of information. I compiled a PDF with all the helpfull repair bits but I don't dare distribute it as I don't want to get in trouble with anyones copywrite.
PostPosted: Tue Sep 13, 2011 8:31 pm
I appreciate your not distributing it. The Hobie Class Association of North America owns the copyright.
Most one-design sailing classes restrict their class magazine to members only. The Hobie Class is unique in that we allow open access to the magazine on-line. We would hope that you find enough value in it to join the class. There are a variety of membership options to suit any Hobie owner.
http://www.hcanamembers.com
PostPosted: Wed Sep 14, 2011 4:56 am
This may not be the best project for someone with little or no fiberglass experience. Working in tight spaces tends to make the job considerably more challenging. But to answer some of your questions-
Regarding sanding, you should always start any composite repair by sanding the surface you plan to bond/laminate to. Sanding helps to clean the surface and also increases the mechanical bond area. I typically use 100 grit paper to scuff/roughen the surface. You also want to do an acetone wipe after sanding. Once you've wiped with acetone, DO NOT touch the surface with bare hands or you'll contaminate it. Wear gloves to keep chemicals off your hands as well as to keep hand oils off of your repair.
I would definitely try to wrap the glass tape around the wing tube. This will provide support in the "hoop" direction and therefore prevent the tube from splitting lengthwise.
I would do a coat of resin around the tube prior to wrapping the tape. This will encourage the tape to stick to the tube where you want it to. You can also wet out the tape on a piece of cardboard or plastic prior to wrapping it around the tube. Then use a brush to work the resin into the glass while wrapping it around the tube. Pre-cut the tape and do a dry run before mixing any resin.
When working inside the hull, it's often very helpful to put a shop lamp inside the hull as well as to have a small mirror so you can see the entire work area. Sometimes taking the boat apart so you can put the hull on it's side or upside down also makes things much easier.
For the inside of the tube, I'd probaby use a brush with an extension to get the resin down into the tube. I'd also use a brush to apply the gelcoat inside the tube (or, more likely, not even worry about gelcoating inside the tube). If you decide to install a porthole and do a wrap around the outside of the tube, then you probably don't even need to do any work on the inside of the tube.
PostPosted: Wed Sep 14, 2011 10:09 am
Thanks SRM good info.
PostPosted: Wed Sep 14, 2011 11:23 am
My primary cat is a Prindle 18, lol. I obtained this H17 for Free and for now once I have it going it will primarily be for my teenage boys to sail. However if I manage to drop a few pounds I may find myself sailing it more. I like that is simple and relatively easy to step the mast by yourself and I love the wings.
I am not a racer but there is a new Hobie fleet down in the southern end of Utah and my oldest may be going to school down there in a year or so. There may be chance he takes the Hobie 17 with him and sails with them a bit but I think mostly of their racing is in H16s.
As for my compilation I made for my self so I would have all the This old Hobie info in one easy place. I highly recommend that you guys put something like this together and make it available in the archive because in my opinion it is the most valuable long term information in the Hotline. Also is it just me or has there not been any new hotlines in a while. I'm still showing a 2010 issue as the latest.
PostPosted: Wed Sep 14, 2011 11:50 am
+1 I think it would be great if something like this was put together and put up on the website with the full Hotline issues. I've been in the process of compiling one myself for all the issues that I would be glad to let the class post with the full issues if you want. I certainly understand why you don't want someone else posting/distributing your copyrighted material, however.
1990 Hobie 18SX #2077
PostPosted: Wed Sep 14, 2011 1:06 pm
When Hobie Cat reorganized their website a while ago, they asked the class to host the HOTLINE.
Current issues (through Summer 2011) are posted here.
PostPosted: Wed Sep 14, 2011 9:03 pm
They should put a link to that on the old archive page. Also I'd be happy to provide my file to hobie but it looks like I need to update it now:)
PostPosted: Thu Mar 29, 2012 6:18 pm
To fix fiberglass cracks on the bottom of the deck fwd of the rear crossbar on the 18 you go through the very bottom of the boat where there is no foam just fiberglass.
Why would you not approach this the same way. That way there is no port hole on deck and you can wrap all the cloth you want around the tube.
Fixing the hole on the bottom of the boat is no fun, but it will leave the boat like original.
The article about doing this on an 18 is in (aug 09) hotline but they refer to another article to patch the hole. Blind hole repair is what is called (june 08).
Sail # 10505 or 277
Image Image
PostPosted: Thu Mar 29, 2012 6:43 pm
The short story is that there is wing tube structure in the way if you approach from the bottom. It's much easier to go at it from the top.
