It is currently Thu Jun 22, 2017 4:46 pm
 Post subject: Hobie Tramp material?
PostPosted: Fri Sep 23, 2011 6:35 pm
What material are the Hobie tramps made from?
Is it used on other Hobie sailing craft?
Can this be purchased in lengths/rolls?
Is there an OEM equivalent that will match the existing AI/TI tramps?
Super-secret project underway... :wink:
PostPosted: Sat Sep 24, 2011 9:41 am
It's a material used in awnings. Phifertex. We have used it on catamaran trampolines... forever. We don't sell it as a raw material.
PostPosted: Wed Sep 28, 2011 8:55 pm
Thanks Matt. We have located it.
Do you know if it is the 70% or 90% shade version?
PostPosted: Thu Sep 29, 2011 8:49 am
The black is part number T54X049560 19 X 19 X04-BLACK if that helps.
PostPosted: Thu Sep 29, 2011 4:40 pm
19X19 may be an custom Phifertex industrial product cuz I don't see it out there.
The 90% shade Phifertex X04 Plus (3007165) is a much tighter 42 x 12 mesh weave designed for slings.
The standard Phifertex X04 70% shade (3006894) is a 17x11 weave and probably the equivalent, judging by the look of my tramps.
Thank you. We'll try to adapt a set of stock Hobie tramps but if that don't work, we'll ask around for Phifertex.
PostPosted: Fri Sep 30, 2011 4:12 pm
It will be interesting to see what you are working on. The Hobie tramps don't look like they are sown but bonded/heat pressed.
PostPosted: Mon Oct 03, 2011 1:56 am
It appears they are triple folded and heat sealed.
PostPosted: Sun Oct 09, 2011 1:48 am
We received sample material from sailrite this week.
The 70% shade cloth is way too thin and porous. The 90% (plus) is about the same thickness as Hobies but a different, finer weave.
I would definitely recommend the 90% cloth for making custom tramps or repairing the Hobie models, even if it is not a perfect match.
The 70% might be a suitable material for spray skirts.
PostPosted: Thu Feb 23, 2012 7:04 am
Hi Nohuhu, I´ve made a spray skirts with the 70% phifertex and it doesn´t work properly because is too porous...
I´m going to try with a double layrs...and we will see if it works...
PostPosted: Thu Feb 23, 2012 10:40 am
80% shadecloth for a Sprayskirt is about as perfect as you can get, and much cheaper.
PostPosted: Fri Feb 24, 2012 10:02 am
I made my TI trampolines with mesh from Sailrite
Very strong durable and inexpensive polypropilene 74" wide sold by the linear yard item #5624 only in black
the thread to use is V-92 Item # 100071 strong and UV resistant
I made a set of tramps for my old larger Tri and they lasted for ever, still in good shape when I sold the boat.
Gil
PostPosted: Fri Feb 24, 2012 11:03 pm
Thanks for adding to the knowlegebase GIl.
This will save others loads of time.
