It is currently Wed Nov 22, 2017 7:10 pm
PostPosted: Thu Oct 27, 2011 3:47 am
I have a Getaway approx 9 years old and the wing seats are quite difficult to push back into their position for trailering. There is a grating noise particularly on the rear strut.
I sprayed some silicone lubricant into all the struts and this has helped however they appear to be returning to their previous grating rough action.
Can they be pulled apart and cleaned/lubricated?
Peter
ps probablythe action of salt water on them over a number of years
PostPosted: Fri Oct 28, 2011 11:29 am
Hobie Tech / Moderator
Those two extrusions should just slide inside each other. There isn't any bearing or anything to get fouled - you might just pull them apart and clean them - I guess you have some sand stuck in there. This is a very odd report, never heard that - and we sell probably 75% of all Getaways with wings...so there's allot of them out there.
Best of luck with the repair. Post up your results so we can all know what you figured out. (might help someone in the future too)
PostPosted: Fri Oct 28, 2011 1:17 pm
Is it possible the strut got slightly bent/bowed? Other than that I can't really think of what would be causing your problem.
PostPosted: Wed Nov 09, 2011 7:04 pm
Check to see if one of the struts or more are bent, I pitchpoled this year and landed on one the forward struts and tweeked it just enough to cause it to bind when opening or closing the wings....hope this helps
Sail on.
Users browsing this forum: Bing [Bot] and 2 guests
