It is currently Fri Jan 19, 2018 2:59 pm
 Post subject: Main sheet control
PostPosted: Mon Mar 12, 2012 11:12 am
Does anyone have input on the utility of a cam cleat on the Hobie inflatables (mine is an i9s) in order to reduce the need to hand-hold main sheet tension?
I'm wondering if a small block with attached cam cleat shackled to the right-side pad eye might be convenient. If so, does anyone have a recommendation for the particular item(s) of hardware, from Hobie or another source. Thanks in advance for your input.
 Post subject: Re: Main sheet control
PostPosted: Mon Mar 12, 2012 7:11 pm
Try this, works great for Trapeze and Vang Cleat.
http://www.apsltd.com/c-1049-clamcleats ... aline.aspx
Greg
PostPosted: Tue Mar 13, 2012 1:52 pm
I put a small Harken block on the stern for the mainsheet, fastened on the stainless hook for the handle. There is now not enough pull on the mainsheet to make holding it an issue, and you can play the sheet in and out easier. You might want to try that before putting a cleat on it.
PostPosted: Thu Mar 15, 2012 7:48 am
Thank you Greg and ewagman. Both suggestions are good and appreciated. I'm going with a serial approach, first ewagman's and then, purhaps, Greg's. Ewagman, will you please provide me the id info for the block you use, and those of other parts employed, if any?
