It is currently Fri Jun 23, 2017 11:10 am
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
PostPosted: Tue Mar 20, 2012 12:14 pm
Sorry for the lack response. I was at a banjo duel.:D 100% of my sailing was done on fresh water. I just hit the exposed ends with CLP after sailing. Now that I'm doing mostly Gulf/Bay sailing, I am going to experiment with dyneema.
All your Page 2 are belong to me.
Jeff
1986 Hobie 18 #13031
PostPosted: Tue Mar 20, 2012 4:07 pm
PostPosted: Tue Mar 20, 2012 4:09 pm
PostPosted: Tue Mar 20, 2012 5:55 pm
You been dipping into the sauce lately Mr. Bounds? :D Some of your posts lately have me wondering... Just saying'.
BTW - where do you find those pictures - you must have an amazing library of them!
Jeff R
'88 H18 Jolly Mon
'10 F18 Closely Called
cramsailing.com
PostPosted: Tue Mar 20, 2012 6:53 pm
Hey MBounds, I would not mess with those skilled with banj itsu!
:lol:
H17
PostPosted: Wed Mar 21, 2012 4:00 am
I'm taller than the first, have more teeth than the second. And of.course my banjo is strung with galvanized wire from Home Depot. In all seriousness to the OP, could the fraying be due to Stress Corrosion Cracking caused by chlorides in the water we sail in reacting with the stainless wire?
Jeff
PostPosted: Wed Mar 21, 2012 4:24 am
Paddle faster I hear Banjo Music.
Bodhisatfa
PostPosted: Wed Mar 21, 2012 6:22 am
There are a number of likely factors that cause standing rigging to degrade and fail - corrosion, cyclical stress (constant load and unload cycles), shock stress (from a high-wind gybe for example), damaged strands (from kinking or abrasion), coiling the wire too tighyly, or simply overloading the shroud. In my experience, most Hobie sailors tend to be pretty rough on their sranding rigging.
An interesting thing I found when looking into having larger diameter shrouds made by some different manufacturers (APS & Loos Co.), none of those manufacturers recommeded (or offered) coated shrouds because the coating allows salt water to be trapped against the shrouds which accelerates corrosion and also makes inspection impossible.
PostPosted: Thu Mar 29, 2012 8:56 am
I asked the metallurgist at work this question and he agreed that it is a combination of load cycles, overall stress and chlorides in the water we sail in (fresh or salt.) He recommended we switch to a Duplex wire, or a higher grade alloy like monel or tantalum. Or just replace the rigging at the first signs of wear...
If you can solve the abrasion resistance of Dyneema that might be the best bet overall. Dyneema plus "Dip-it" perhaps?
Jeff
