It is currently Thu Mar 28, 2024 11:35 am
PostPosted: Thu Apr 19, 2012 1:26 pm
My exchange Humminbird transducer came in and I just installed it. Took a bit over an hour, including photo setup time. Easy Pleasy. Here's the sequence.
Inside the PA14, before beginning...
I used the rubber gasket to mark out where the big hole will go...
I drilled a small pilot hole, and then took the irrevocable step with a hole saw. No turning back now!
I ran a generous bead of Marine Goop around the transducer and on the outside of the hull, then ran a bead inside the hull where the rubber seal will go. Then I hand tightened the plastic nut from inside...
I finger-smoothed the GOOP on the outside. Here's the transducer from the bottom of the hull. It protrudes 0.2" and is smooth...
I'll clean up the excess GOOP when it dries. That's it! Topside, the install is the well-known Ram wedge mount and 1" ball mount. No need to show that.
Pro Angler-14 owner
PostPosted: Thu Apr 19, 2012 2:17 pm
Wow :o ...You have gone where most of us fear to tred. You'll have to let us know how it works for you.
Cheers
Cheers,
Adam
http://www.yakfisher.net
PostPosted: Thu Apr 19, 2012 2:36 pm
:o :o :o :shock: :shock: :shock: :o :o :o :o
2011 HPA
2006 Wildy Ride 135
2019 Hobie Compass
2020 Hobie Outback
PostPosted: Thu Apr 19, 2012 2:58 pm
Yep...I agree. That took courage. It will be interesting to know how that setup holds up over time and usage.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Thu Apr 19, 2012 3:13 pm
Steve, I flew 300 combat missions over Cambodia in a Cessna, alone. Trust me, drilling a hole didn't scare me all that much.
Pro Angler-14 owner
PostPosted: Thu Apr 19, 2012 4:44 pm
RockyRaab,
After stating that I'm absoultely postive you have the courage. Thanks for your service. I have time airborne over Laos and Cambodia myself flying combat type missions. Welcome to the PA owners fraternity!
Respectful regards,
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Thu Apr 19, 2012 5:06 pm
You too, my brother.
And now, back to our regularly scheduled program...
Pro Angler-14 owner
PostPosted: Thu Apr 19, 2012 6:28 pm
It takes real courage to jump out of those things you all flew. :lol: Just jokeing. You all got us there in one piece. My favorite will always be C130 baby. :D Thanks for the ride!!! :mrgreen: On the flip side is that for the DI?
Steve Valerga Jr.
DV U.S.Army Airborne
1988-92
2012 Pro Angler
Take a kid fishing!
PostPosted: Thu Apr 19, 2012 6:41 pm
Steve
I see you're in central Texas. I've fished Whitney and McQueeny (hope I spelled that right? near Austin) in my 5 years stationed in Texas. I'll bet it's a different experience in a PA versus a bass boat...lol.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Ziptailz Ambassador
PostPosted: Thu Apr 19, 2012 7:01 pm
I havent got up there yet. My first two weekends I had my son with me, and even though he likes it in the back I am not comfortable taking him on big lakes. Last weekend we had horrible wind. I finally got a couple hours in on sunday night so I hit the same old pond. Looking forward till sat. and going to hit Lake Buchannon for some whites and stripers. Those lakes are north about an hour and half. We have so many here in the highland area. I also have family in the Rockport/ Baycity area. Going there on the 27 to get salt slimed and family reunion. Be sending pics soon. Didnt mean to change the topic, sorry all. Yes you did spell the lakes right.
Steve Valerga Jr.
1988-92
2012 Pro Angler
Take a kid fishing!
PostPosted: Thu Apr 19, 2012 7:20 pm
RR - I am not at all familar with that ducer. Does it fit snugly enough in the PVC tube to prevent water from coming in around it? Looks like the top of the tube is below water level, which could mean...
PostPosted: Thu Apr 19, 2012 7:46 pm
this pretty much sums up my thoughts...
2019 Hobie Outback Slate Blue
2018 Hobie Compass Seagrass Green
2012 Hobie Pro Angler w/MD180 Papaya Orange
ex 2012 Hobie Tandem Island
ex 2011 Hobie Pro Angler
ex 2011 Hobie Adventure Island
ex 2010 Hobie Adventure Island
PostPosted: Fri Apr 20, 2012 7:13 am
Jim, the 'ducer itself is mounted inside that tube, completely embedded in epoxy. There's no way in heck any water will get through the transducer. The only possibility of a leak is around the outer tube, and that is now sealed with GOOP and a rubber washer. I'm going to put it in the water today, and I'll report back.
Pro Angler-14 owner
PostPosted: Fri Apr 20, 2012 8:23 am
It'll be fine. I have a kayak (Mokai) with internal ribbing which requires about a dozen or more fittings through the bottom of the hull. They are sealed with tiny o-rings. Never have I taken any water inside the hull.
The GOOP is double insurance. I'd be shocked if it were to ever leak.
PostPosted: Fri Apr 20, 2012 9:14 am
Would it void the warrantee?
2011 HPA
2006 Wildy Ride 135
2019 Hobie Compass
2020 Hobie Outback
